10.8v
what is the battery showing ?
3v is not good
Posted 08 June 2016 - 05:53 PM
10.8v
3v is not good
Posted 08 June 2016 - 05:55 PM
FB19 supplies both circuits, so start with the terminals for that fuse
Edited by vocky, 08 June 2016 - 05:55 PM.
Posted 08 June 2016 - 05:57 PM
Posted 08 June 2016 - 05:59 PM
with the fuse back in can you check that the voltage is coming out the other side ?
It only goes to the sidelight and headlight switches - both pin 3
Posted 08 June 2016 - 06:01 PM
also worth checking the voltage with the switches both removed, just in case you have a blown sidelight bulb pulling the voltage down
Posted 08 June 2016 - 06:11 PM
Posted 08 June 2016 - 06:20 PM
if that is with both switches removed then your problem is between FB19 and the pins number 3 of the switches
I would check the fuse holder first, try and access the Brown/Blue strip wire underneath the fuse box and see if that has 11.8v or 4v
My guess would be corrosion of the fuse terminals, but the other option is a broken wire.
Posted 08 June 2016 - 06:21 PM
Posted 08 June 2016 - 07:31 PM
run a temporary wire to the switches from the battery, if the lights work then the original wire is broken somewhere
Posted 08 June 2016 - 08:01 PM
Posted 14 June 2016 - 05:06 PM
