Master Cylinder Replacement Advice
27 replies to this topic
#21 FLD
Posted 08 July 2016 - 08:57 PM
Imagine a balance bar where the servo is rather than on the pedal. The pedal pushes the second bar which is on a pivot. Saves fannying with the pedals. I'll see if I can find a pic. Sent from my iPhone using Tapatalk
#22 FLD
Posted 08 July 2016 - 09:02 PM
Something like http://www.compbrake...bias-pedal-box/ Sent from my iPhone using Tapatalk
#23 jbt
jbt
  • 10 posts
Posted 08 July 2016 - 09:28 PM
You could also make a custom brake pedal like Pilbeam's and then retain the original pedal box.
Edited by jbt, 08 July 2016 - 09:30 PM.
#24 karlbac
karlbac
  • 110 posts
  • Interests:Cars - VTT
Posted 09 July 2016 - 05:58 AM
I see my question unearthed an old debate about servo deletion
But wasn't the object, just need the best MC combo
Jbt : the Pilbeam seems to be an easy way to convert the pedal box but I just bought 2 AP Racing master cylinders CP6465-173 and CP6465-188 they are quite versatile with the trunnion system
I'll give you my feeling once installed
#25 Arno
Arno
  • 1,238 posts
Posted 09 July 2016 - 10:17 AM
Also from Germany there's a balance-bar setup that's mounted behind/on the servo:
Not sure it's small enough to fit inside a VX though..
http://www.isa-racin...nengewinde.html
#26 FLD
Posted 09 July 2016 - 10:48 AM
These won't fit with the existing pedal box as it fouls:( You end up with the balance bar ends where the other pedals are. Sent from my iPhone using Tapatalk
#27 jbt
jbt
  • 10 posts
Posted 09 July 2016 - 01:32 PM
Are the pedals closer on the speedster than a Toyota Elise? I though the tub was almost the same.
#28 FLD
Posted 09 July 2016 - 04:36 PM
Not seen the Elise but I looked at putting a bias bar in the pedal and it doesn't fit. Sent from my iPhone using Tapatalk
