My throttle cable is now spot on but my engine runs like a bag of bolts as low rpm's, sometimes tick over is lumpy, sometimes it's smooth, it sounds like it's going to stall when you give minimal gas before it revs up to 2-3000 rpm and today the eml flickered when I pressed the gas a tiny bit at tick over, it always smells of fuel and it occasionally back fires when coming off the gas suddenly at very low speeds. Does anyone think Northampton motor sport will be able to resolve any of these issues?
Also the red LED light in the engine bay is always on, Vocky said something about this being for diagnostics but I can't quite remember what?
It does drive superbly at 10%+ open throttle and uses surprisingly very little oil for a forged piston engine, but I do let it thoroughly warm up before I drive it very fast.
This is the engine spec:
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]218.8bhp[/font]
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]Saab Block[/font]
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]Webcon ITB kit[/font]
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]Alpha Pro 4 ECU[/font]
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]Comp Cams Stage 2[/font]
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]Double valve springs [/font]
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]Forged pistons [/font]
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]Steel con rods[/font]
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]ZY crank shaft[/font]
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]Balancer shaft delete[/font]
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]Chris Tullet 4-1 manifold[/font]
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]Chris Tullet 2.5 in complete exhaust[/font]
[font="'Roboto Slab', 'Times New Roman', serif;background-color:rgb(250,250,250);"]TTV light weight flywheel[/font]
