Poor Idle And Low Rpm Running.
37 replies to this topic
#21 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 12:31 PM
how about four carbs on there?
Carbs  Imnotworthy
May have a problem with my emissions test next MOT though. May also use a lot more fuel and lose power.
#22 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 12:33 PM
Alan mapped my 2.2 engine, which is now sat in your car, I now have a 2.5 engine with additional tweaks and had it mapped at NMS.   He spent a week mapping the 2.2 engine, NMS had only a morning. Therefore it was never going to be as good due to the time constraint.
Does that mean your ECU is perfectly set up for my engine? I can buy your ECU please? :D
the map was 241bhp and has been over written by the latest 270+ map, so pretty useless for you :P
Your car had a new TPS fitted a few years ago by Joey and the ECU has Fab's map on it (220-230 bhp)
I have the voltage written down somewhere for the TPS on Fab's map
Does that mean that I need to steal Fabs engine now as well as your gearbox and seats? I'll add it to my list if so.  :ninja:
#23 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 12:34 PM
Unless someone has changed it the TPS should be set to 0.717v
So I get to use this thing I bought the other week?
Posted Image2016-07-29_01-28-11 by Richard Fanders, on Flickr
#24 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 12:51 PM
Found this: http://www.vx220.org...one-this/page-2
#25 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 01:08 PM
I guess my arrow is pointing to the TPS? Just found out that a TPS is a potentiometer. How would I test this?
Posted Image20160729_140012 by Richard Fanders, on Flickr
Edited by gaffer1986, 29 July 2016 - 01:17 PM.
#26 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 01:09 PM
Also, my ITBs get soaked when it rains, that surely can't be good?
#27 fezzasus
Posted 29 July 2016 - 01:20 PM
A bit of water injection never hurt anything (plus, consider the typical amount of spray a engine collects in the rain).
Why even bother with the Webcon ECU? Surely you could a proper standalone?
Edited by fezzasus, 29 July 2016 - 01:21 PM.
#28 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 01:22 PM
A bit of water injection never hurt anything (plus, consider the typical amount of spray a engine collects in the rain).   Why even bother with the Webcon ECU? Surely you could fit an Emerald or similar?
I didn't know there were other ecu's available for this system. That's another good option although sounds like I would have to change a lot and get it remapped anyway.
#29 fezzasus
Posted 29 July 2016 - 01:44 PM
To be clear I can't promise that any ECU will work out of the box, however I was of the understanding that one of the issues with fitting a stand alone ECU to the VX220 was the use of a fly by wire throttle pedal. You've already changed that on yours.
#30 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 01:46 PM
Do you think all the existing sensors would work?
#31 fezzasus
Posted 29 July 2016 - 01:47 PM
http://www.msextra.c...ature-xref.html
http://www.msextra.c...p?f=104&t=41043
Edited by fezzasus, 29 July 2016 - 01:48 PM.
#32 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 01:51 PM
Starting to sound like a lot of sentences I don't understand. I may stick with the Webcon and see if I can take this Alan guy hostage until he sorts it.
#33 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 01:55 PM
Think I've found him, if he goes missing for a week it wasn't me.  :ninja:
Posted ImageAlan Collins by Richard Fanders, on Flickr
#34 oakmere
oakmere
  • 2,143 posts
Posted 29 July 2016 - 02:58 PM
The throttle position sensor looks very similar to the one I had on a Webber alpha carb setup. Vocky should let you know which cables to check the voltage across. If it is like mine was just tightening the screws adjusts the voltage so it is a bit of trial and error until you get an acceptable reading. Have fun
#35 vocky
Posted 29 July 2016 - 03:15 PM
the plug you need to access is shown in the lower section of your photo - the one which you can see with AMP written on it. (AMP is the manufacturer)
With the ignition turned on adjust the voltage at the Throttle Position Sensor (TPS).
To do this, connect a volt meter to terminal 1 blue wire and terminal 2 (centre) blue/purple wire of the harness connector.
The Throttle Position Sensor voltage reading requires setting to roughly 0.717 volts.
Once again, open and close the throttle a few times to make sure they are fully closing and that the voltage reading remains at roughly 0.717 volts.
#36 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 03:30 PM
Thank you, I thought so. I called Northampton Motorsport and they booking for 08/09/16 :o I may try and track down Allan and see if he would agree to help.
#37 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 03:33 PM
This information is really helpful thanks Neil. What leads from the volt meter do I connect to the blue and blue/purple wire. Should I set the multimeter to ohms to measure resistance? What resistance am I likely to get?
#38 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 03:34 PM
Oh, I see, testing the voltage, sorry. 20v dc will do?
