Engine 'hunting' When Running
25 replies to this topic
#21 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 16 May 2017 - 07:07 AM
Sheesh, get them to do the first point on my list.
They can also isolate the MAF (even if it's brand new) by disconnecting it and the ECU will run in open loop mode (thus eliminating it (and any possible wiring problem to it) from the list of culprits).
Done it all wishbone bolt boy :D
#22 Nev
Posted 16 May 2017 - 07:32 AM
What was it in the end?
#23 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 16 May 2017 - 07:35 AM
Work in progress. Its actually misfiring under load the hunting was sorted with a lambda some time ago. Intermittent problem I'd previously driven it for 2 hours with no issues then its back again. We have tested all the easy stuff.
#24 siztenboots
Posted 16 May 2017 - 07:40 AM
Jon I will give you a call later
#25 Horace
Horace
  • 1,290 posts
Posted 24 May 2017 - 07:29 PM
Hello fellow enthusiasts (that doesn't include me right now  :([color=rgb(34,34,34);font-family:'Helvetica Neue', Arial, Verdana, sans-serif;]  )[/color]
[color=rgb(34,34,34);font-family:'Helvetica Neue', Arial, Verdana, sans-serif;]Just a quick update:[/color]
Swapped out/replaced so far:
  • MAF
  • MAP sensor
  • Coil pack
  • Spark plugs
  • Boost solenoid
  • O2 lambda sensor
  • Throttle body
  • Injectors
  • Fuel rail
  • Fuel pressure regulator
Still not bottomed out the u1200 error on opcom, but I believe another ecu is on the way
Any news on that napalm?
#26 Nev
Posted 26 May 2017 - 07:52 PM
Has the entire charge pipework been properly pressure tested yet (from airbox to cylinder head)?
If it has, and assuming it's not the problem, then there are quite a few other things to check. For a start, a faulty bypass valve (and connecting vac pipework + bypass solenoid) would be my next check. After that, cam sensor, waste gate housing crack, faulty actuator etc etc.
Idling issues are unlikely to be an ECU problem IMO, in fact if the revs are hunting it shows the ECU is probably working well and is trying to compensate for whatever the fault is.
Edited by Nev, 26 May 2017 - 08:17 PM.
