Posted 24 November 2016 - 02:48 PM
Posted 24 November 2016 - 02:55 PM
Start at the headlights and work back. It will probably be the connectors behind the headlights.
Posted 24 November 2016 - 03:00 PM
Posted 24 November 2016 - 03:01 PM
check the negative cable to the lefthand headlight unit - it is the black wire(s)
https://www.speedste...m/High beam.pdf
Edited by vocky, 24 November 2016 - 03:02 PM.
Posted 24 November 2016 - 03:07 PM
Posted 24 November 2016 - 03:25 PM
Thanks folks. Will check these at the weekend and see what can be done. No doubt this willl end up costing somewhere around £600 if my vx year is to be continued.
I'll fix it for you for you for £550
Posted 24 November 2016 - 04:54 PM
Posted 24 November 2016 - 10:58 PM
When I resealed my lenses I plugged the headlights in and the left indicator didn't work. I cleaned the contacts and they were fine! Hopefully it's something similar for you!
Posted 26 November 2016 - 02:19 PM
Posted 26 November 2016 - 04:16 PM
going by the symptoms you describe in the first post, it would appear that the negative feed is not getting to the L/H headlight, whether thats a broken wire or something elses requires further investigation. Or possibly something is shorting out the headlight when on main beam.
I could have a look if you want to pop down.
Edited by vocky, 26 November 2016 - 04:17 PM.
Also tagged with one or more of these keywords: lighrs, electrics, ffs
General Discussion →
VX220 Discussion →
Starter Relay Or Starter Problem? Help?Started by ee601 , 31 Dec 2016 ![]() |
Welcome to VX220.org.uk →
Introduce Yourself - Newbies & Forum Guide →
Need Help With Vx220 RebuildStarted by 7214cars , 14 Aug 2015 ![]() |
