Abs Troubleshooting Rear Sensor / Circuit
35 replies to this topic
#1 glitch
glitch
  • 275 posts
Posted 12 January 2017 - 08:13 AM
Hi guys,
trying to sort all the small niggles on the VX before being able to do the import registration here in Sweden.
The ABS has been previously disabled via a switch in the front.
ABS light however stays on even after switching it to "On".
It seems to be inserted along a black wire? I thought it was a yellow one that is normally cut?
I managed finally to get OPCOM working, and cleared a bunch of fault codes linked to the ABS, but one of them keeps coming back directly after clearing.
It says it has an issue with the rear circuit right side.
I thought this one is the one also driving the speedo? Because last time I drove the car speedo worked fined.
I have also measured the voltage and the connector going to the ABS shows 5V as I believe it should?
Not sure what to try next.
Thanks!
#2 james_ly
james_ly
  • 864 posts
Posted 12 January 2017 - 08:48 AM
Have you driven the car since reconnecting the ABS? On my car you have to go over 5mph or so before the light goes out again. Or I was just impatient...
#3 smiley
Posted 12 January 2017 - 09:01 AM
Speedo is rear left.
#4 glitch
glitch
  • 275 posts
Posted 12 January 2017 - 10:23 AM
Hi James,
just driven the car briefly after reconnecting the ABS, and this was before the code resetting with OPCOM and the light stayed on at that time.
#5 glitch
glitch
  • 275 posts
Posted 12 January 2017 - 01:19 PM
I also checked the cables going into the wheel bearing and they look fine and properly connected so no frayed cables from what I can see.
#6 PaulCP
PaulCP
  • 6,064 posts
Posted 12 January 2017 - 01:43 PM
Have you checked that the switch is working ok. This happened to me once and the culprit was a faulty switch Also, presumably you are turning the ABS back on with the ignition switched off & not with the engine running?
Edited by PaulCP, 12 January 2017 - 01:44 PM.
#7 CHILL Gone DUTCH
Posted 12 January 2017 - 02:39 PM
You have to drive it a short distance to reset the abs after switch it on Looking at that switch I would remove it a connect the wired together
#8 glitch
glitch
  • 275 posts
Posted 12 January 2017 - 04:24 PM
Hi,
Yes i switched the ABS "back on" with the ignition off.
I will try to disconnect the switch and connect the wire back together to ensure I have a good connection so I can rule that out.
When I reset the ABS in OPCOM it immediately displays the error codes again so it seems something is still triggering the fault code - I suppose driving it wouldn't change much as I suppose the light goes off after the car is driven for a while and the system runs "fault free" for a period of time?
#9 CHILL Gone DUTCH
Posted 12 January 2017 - 04:34 PM
its more it needs to find its self after switching it back on
hopfully it wont come back on until you switch it off again
#10 oblomov
oblomov
  • 3,762 posts
  • Interests:None
Posted 12 January 2017 - 06:50 PM
Has the car been standing for any length of time? I've had to change the rear passenger sensor twice through malfunction after the car had been standing for a period of time.
Edited by oblomov, 12 January 2017 - 06:50 PM.
#11 glitch
glitch
  • 275 posts
Posted 12 January 2017 - 08:25 PM
Hi, I think the car stood some weeks due to infrequent use with previous owner. Since in my custody it has just been standing :) How did you sort the sensors? Note mine is on the right side (driver side).
#12 Exmantaa
Posted 12 January 2017 - 09:16 PM
You can measure the resistance of each ABS sensor at the hub connector; should be around 1400 Ohm.
#13 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,509 posts
    "Yes, I built it"
Posted 13 January 2017 - 09:28 AM
Switch used to work fine before I sold the car, your opcom output points to rear right, I know I changed all wheel bearing but thinking about it was a while ago now so might of developed a fault.
ABS was rubbish even on the road, wouldn't even bother with it on track, most do the 4 channel unit but reports on that are 50/50.
#14 glitch
glitch
  • 275 posts
Posted 13 January 2017 - 11:35 AM
Basically unplug the abs sensor from the loom, and measure the two pins of the female connector attached to the wheel bearing?
#15 Pidgeon
Pidgeon
  • 5,254 posts
Posted 13 January 2017 - 12:29 PM
Easiest way I find to troubleshoot the ABS is by detecting signals at the ABS plug.  There's a key somewhere on here to where the 8 wires run in the plug.  If there's signal there with the wheel being turns by a helper, your problem is upstream.
#16 Exmantaa
Posted 13 January 2017 - 01:49 PM
Yep; unplug the connector and measure accross the 2 pins. If that measures OK (wiggle the wires to check for intermitting contacts), you then need to look towards the ABS wiring. (check for continuety or shorts. There is a scheme of the ABS connector pins somewhere.)
#17 glitch
glitch
  • 275 posts
Posted 23 January 2017 - 01:52 PM
Haven't had time to go to the car yet, but just a quick question, if my harness was damaged somewhere along the circuit for rear right sensor, shouldn't I then get a 0 voltage reading from the ABS plug at the end of the harness? As today it measures 5v?
I thought that if there was an interuption in the wiring, then there would be no positive voltage i.e. a break in the harness cable would interupt the voltage?
But then again maybe that is not at all how it works :)
#18 glitch
glitch
  • 275 posts
Posted 13 February 2017 - 10:33 AM
So I spent some time with the car this weekend.
I removed the ABS switch and made a new connection of the yellow wire - so now it is 100% connected.
I measured resistance at the plug connector of the wheel sensor. It seems to measure OK?
I measured voltage at the connector coming from the loom which plugs into the ABS wheel bearing sensor. Also seems OK?
Not sure what to do next? I seem to have power in the loom and the bearing sensor seems OK?
Edited by glitch, 13 February 2017 - 10:34 AM.
#19 glitch
glitch
  • 275 posts
Posted 13 February 2017 - 10:52 AM
I hope I set it up right for measuring Ohm? Never done it before :)
#20 glitch
glitch
  • 275 posts
Posted 20 February 2017 - 03:19 PM
Help anyone? Stuck on this. Not sure what to try next - or how to proceed?
Had I lived in the UK the obvious thing was to buy my way out of this issue by dropping the car at a workshop which knows their way around a VX but I am out of luck on that point here :/
