As a very soon to be owner (I will spill all soon) I would like to know the best places to get service items, especially a cam belt kit.
Also what oil do these bests need?
If anyone has a CD copy of the manual would you be kind enough to PM me
Posted 19 January 2017 - 11:36 PM
Posted 19 January 2017 - 11:50 PM
Autovaux tend to be cheapest on service items, best to ring them though. They can supply almost anything, even if it's not listed on the website. Prices over the phone are usually better too
Posted 19 January 2017 - 11:53 PM
I meant the workshop manual.
I tried the drop box one but it keeps freezing mid download.
I know there is an online copy but a cd/dvd on my laptop would be so useful.
Cheers
Posted 20 January 2017 - 12:03 AM
Euro Car Parts for service items
Posted 20 January 2017 - 12:11 PM
As above but get bosch or something as some parts are cheap chinese things.
Some things are far cheaper if you search for the equivalent Astra/Zafira items. To give an example, in the past most places sold VX220 clutch slave cylinders for around £120. However I used to buy the exact same Astra item for £55 off eBay.
As is often the case, the retail price of the item is not related to the manufacturing cost what-so-ever (rather like over expensive bling watches (yes, I thought I'd hammer this one home again!!)).
*Preparing for flaming*
Edited by Nev, 20 January 2017 - 12:12 PM.
Posted 20 January 2017 - 12:16 PM
Any advise on what make cam belt kit to get?
I usually stick to conti belt.
Posted 20 January 2017 - 12:18 PM
Hmm, I can't remember what I put on last, but I'd stick with OEM if you can as it is a critical part that you can't inspect easily.
"the exact same"?
"the same" would do, or "exactly the same" if you must.
Posted 20 January 2017 - 12:20 PM
"the exact same"?
You are right Foxy, I need to brush up my grammar.
Edit: Although by "exact same" I was implying it was the identical manufacturer as the OEM item (as opposed to a pattern part made by a different manufacturer).
Edited by Nev, 20 January 2017 - 12:29 PM.
Posted 20 January 2017 - 12:23 PM
When did this turn into a lesson in grammar?
Posted 20 January 2017 - 12:26 PM
When nev posted
While where at it, it's 'advice' you're after, not 'advise'.
Edited by Foxy, 20 January 2017 - 12:28 PM.
Posted 20 January 2017 - 12:30 PM
When nev posted
Now that's not fair, where did I ever write "advise"?
Posted 20 January 2017 - 12:32 PM
Do I have to write lines?
Didn't realise owning a 220 came with English lessons.
Posted 20 January 2017 - 12:47 PM
Yes, lots. That's the usual penalty. The is no room for complacency, we have standards to uphold.
Posted 20 January 2017 - 12:51 PM
When nev posted
Posted 04 October 2016 - 10:44 AM
When you install the old/new one, I'd advise fitting a lock nut over the existing M10 nut, as turbos have a habit of unwinding bolts near them (due to the high freq vibrations).
Posted 20 January 2017 - 01:01 PM
Posted 20 January 2017 - 01:25 PM
Gates, Conti-Tech, Dayco in that order for timing belt kits personally.
Posted 20 January 2017 - 01:57 PM
When nev posted
That's correct usage by me, you dummy! I was using the verb "advise". You are getting confused with the noun "advice".
Read here to see the difference: http://www.grammar-m...vice_advise.htm
Edited by Nev, 20 January 2017 - 02:02 PM.
