Air Filter Recommendations
Posted 16 February 2017 - 11:26 AM
Posted 16 February 2017 - 11:36 AM
You can clean them, they're just not oil based so you don't need to oil them afterwards.
You can easily clean them with standard air filter cleaner, water or even a weak soapy mixture as long as you make sure to dry it out properly afterwards
But if you're going to throw it away i'd take it off your hands
Posted 16 February 2017 - 11:52 AM
Whats wrong with the standard air filter?
I know that when the VXR was first introduced it had an oil based air filter (as I recall) that was then changed out for the standard paper one again as I recall, it might have been the other way round.
I blew an AMM, and returned the car under warranty they changed the filter for a paper one and it has been OK since and it is at stage 4.
Posted 16 February 2017 - 01:11 PM
Posted 16 February 2017 - 01:18 PM
Posted 16 February 2017 - 01:32 PM
Posted 16 February 2017 - 02:18 PM
Edited by tibby, 16 February 2017 - 02:22 PM.
Posted 16 February 2017 - 03:54 PM
vxr originally had a foam type filter , but the foam would break down with heat in the bay and break off and get stuck to the heated wire on the MAF, which would then overheat and break.
how many people on here have actually had an oiled filter and broken there hot wire MAF , versus those that broke their MAF with a paper/dry filter.
bear in the mind the standard crankcase ventilation , goes directly in just behind the MAF , so the oil will still try to get out to atmosphere , past the MAF when the recirc closes.
Posted 16 February 2017 - 04:04 PM
Posted 16 February 2017 - 08:01 PM
Posted 16 February 2017 - 08:08 PM
I've been chatting with Dave about a few other things too. I'd like a ride in a car with one first before I considered it. I don't want the induction sounds dampened too much. In the mean time I'll have a go at washing the Apexi. Stuck half way through doing the timing belt at the moment, one of the engine mounting bolts is seized Trying a good soaking of penetrating fluid over night. Then I'll wash the filter. Thanks for all the input fellow vx'ers.The air intake kit I did with Dave Hardwick with oem filter Not the cheapest option but proven to be better than open cone and host of other aftermarket kits with the best filtration and fantastic quality Loads of testing on the road and rr, yet to be bettered 😉 DG
Posted 17 February 2017 - 09:03 PM
Apexi are a good filter and on test with skyline come out the best, different car I know but for filtration and flow they beat all the top brands including HKS etc...
Just wash it and leave to dry for a few days
Posted 17 February 2017 - 11:03 PM
Posted 17 February 2017 - 11:55 PM
Posted 17 February 2017 - 11:57 PM
While it's out, have a good look at it.
Posted 18 February 2017 - 12:04 AM
Posted 18 February 2017 - 11:31 AM
Another for the Apexi... albeit I think I do damage my passengers ear drums. I am happy just to buy a new element when the old one is past its best (just about to change it after 3 years and still looks new!), however, I only do 1000 miles per year and dry use only... I imagine it could get very dirty if pounding up and down the motorway in winter every day! You can however buy/make a shield which should help.
Posted 18 February 2017 - 11:46 AM
done back to back tests with standard vxt box and paper filter and the apexi had worse mass air flow sensor readings
running the biggest k+n made a huge difference in flow and noise , it was the harsh noise which was damaging hearing on long trips
Posted 18 February 2017 - 02:33 PM
Yup, another vote for the DH unit. I bought one, eye watering price but it just made sense as breathing is such a fundamental part of the car. I haven't done a dyno on it as it was smoothness I was after rather Ham pure HBO. I like the way it uses the stock filter which is reassuring. Any bhp gains are a bonus but if it delivers similar results to the tests then £ per bhp it's a bargain, especially once you are already at a stage 4 tune. P.s. Hi DuncanThe air intake kit I did with Dave Hardwick with oem filter Not the cheapest option but proven to be better than open cone and host of other aftermarket kits with the best filtration and fantastic quality Loads of testing on the road and rr, yet to be bettered 😉 DG
