Air Filter Recommendations
#21
Posted 18 February 2017 - 02:45 PM
#22
Posted 18 February 2017 - 04:31 PM
done back to back tests with standard vxt box and paper filter and the apexi had worse mass air flow sensor readings
running the biggest k+n made a huge difference in flow and noise , it was the harsh noise which was damaging hearing on long trips
Sadly it's true.....
Carsten (German guy who did sell his stage 5.5 turbo recently) had 0.4 bar less boost with a Apexi filter. He also went for the big K&N type.
text:
Keine 380PS mehr, eher nur noch etwa 300. Grund: im mittleren Drehzahlbereich erreiche ich noch 1.8 bar Ladedruck, was jetzt aber wieder ein Overboost ist. Mit steigender Drehzahl fällt der Ladedruck auf 1.4 bar ab bei Schaltdrehzahl. Also ganz klar: der A'PEXi-Filter ist zu klein!
Edited by tibby, 18 February 2017 - 04:40 PM.
#23
Posted 18 February 2017 - 06:33 PM
#24
Posted 19 February 2017 - 06:00 PM
Loads of testing on the road and rr, yet to be bettered 😉
Ahhhem...! JK, I know my system is obtuse and not to everyones taste!
Hi Simon, it is really worth paying attention to the flow rate (i.e. pressure drop across the filter), as there is a good deal of gains to be had on a car like yours by ensuring a minimal vacuum. I played around with a couple of filters and then made my own and got about 60 HP extra. Others on high powered cars have had similar stories, Carsten above being one (so that huge filter that he used is a good bet).
Edited by Nev, 19 February 2017 - 06:04 PM.
#25
Posted 19 February 2017 - 08:06 PM
