Is It Worth Claiming On Insurance
Posted 16 February 2017 - 04:11 PM
Posted 16 February 2017 - 04:12 PM
Bummer. Personally I wouldn't.
Posted 16 February 2017 - 04:33 PM
unless youve got a proper agreed value policy, she'll be a write off if you claim
Is it a standard wiring loom or modded for the twin carbs/pump etc?
When sorting it, WEAR GLOVES as wiring insulation becomes evil evil evil stuff when exposed to a thermal event
Posted 16 February 2017 - 05:14 PM
I had this happen with a 205Gti Mi16 on carbs. I would suggest not claiming - it'll count against you and they aren't likely to offer much. Once it's all cleaned up the damage is probably pretty minor if you put it out quickly, a bonnet paint and some new hoses, wires and belts and you'll be well away. Just take your time with it, and it'll be as good as new I would think. Was likely the bonnet lining being saturated with fuel, then the carbs spitting a little flame on startup - at least that's what happened to me. Dry powder is horrible and corrosive by the way, I'd get the all cleaned off ASAP if you do plan to resurrect it.
Posted 17 February 2017 - 07:18 AM
Posted 17 February 2017 - 08:39 AM
