Quantum Zero Issues
Posted 14 March 2017 - 07:33 AM
Posted 15 March 2017 - 04:01 PM
Better question, who has a set of Quantum Zeros? Do they squeak at all, e.g if you a driving with the windows closed and the stereo off at 30mph can you hear each corner noticeably churping as you go over bumps?
I have so much squeaking when going straight, and turning that just wasn't present on the standard billies. Seriously it can't be normal.
Wish I'd never bought the things at the moment.
Posted 15 March 2017 - 05:39 PM
Posted 15 March 2017 - 05:55 PM
Some pictures here, with the car jacked up and on full droop.
https://goo.gl/photo...VatiA6ijcLau6T8
You can see where the spring has rubbed the chassis and marked it and you can also see where the black paint has rubbed off the spring from where I adjusted the collar and it roated the spring as well.
I found last night that actually both rears rest against the chassis on full droop, not just the drivers side.
Posted 15 March 2017 - 06:00 PM
Posted 15 March 2017 - 06:53 PM
Posted 16 March 2017 - 10:40 AM
I had the same with my rear nitrons as the spring was 8" , I had loads of spare platform thread below , so no need , so replaced with Nitron for a 6" and a 2" helper with compresses normally to almost nothing flat.
Posted 16 March 2017 - 10:55 AM
Is the spring loose at full droop?
Posted 16 March 2017 - 11:09 AM
no because its got 2" of extra adjustment to get the preload I want and ride height. tbh springs loose is more a problem on the front at about 110-120mm RH
Posted 16 March 2017 - 02:09 PM
Posted 16 March 2017 - 02:38 PM
Are they brand new? Pretty much impossible to fit them wrong IMO...
Posted 16 March 2017 - 02:47 PM
Posted 16 March 2017 - 03:28 PM
Did you put grease on the o-rings for the damper eye things?
Posted 16 March 2017 - 03:50 PM
Had the same kind of rubbing there with some 46 shocks @ droop.
Decided it was due to tolerances in the subframe; Block of wood plus few moderate hammer strikes in that area and all was fine.
Posted 16 March 2017 - 04:05 PM
I haven't, I was told not to grease anything. Just fit and bolt up.
I did ask several times about if I should have greased anything.
Did you grease them?
Posted 16 March 2017 - 04:12 PM
I don't have Quantums and I bought my NSS second hand... so I haven't actually done this. Maybe it's greased from factory.
Following with interest as I am thinking of upgrading dampers. But in the last month I've read about Nitron NTRs not coming with helper springs... and now this. Don't know what to think!
Posted 16 March 2017 - 08:50 PM
Edited by Mattyboi, 16 March 2017 - 08:51 PM.
Posted 17 March 2017 - 09:02 AM
Your springs seem awfully wide for the seat as they are exending past the edge. Were perhaps 2.5" springs fitted instead of 2.25" ones?
Posted 17 March 2017 - 09:20 AM
Well spotted, yes this looks likely to me. Even if they are the correct 2.25" ones, it their fitment looks worrying.
A possible solution is to take the top coilover mounting bracket off. Make a 2mm or 3mm flat plate spacer to go under the mounting bracket, which will thus push the whole assembly out a bit (away from the chassis). This will in effect slight modify your effective spring LB and valve rate (due to the minor angle change), but barely anything.
Edited by Nev, 17 March 2017 - 09:21 AM.
