I still got issues with these dampers.
They had 3 noises ( none of which I had on standard dampers ).
- [color=#008000;]a chrip all the time as the damper deal with any bumps - which has now gone ( quantum closed off the bleed valve or something )[/color]
- [color=#ff0000;]lots of creaking/squeaking at low speeds, small roundabouts, turning in and out of junctions etc[/color]
- [color=#ff0000;]a weird noise when hitting harder bumps, normally downward bumps kind of like a reversed speed bump, I get a weird noise from whichever corner hits the bump. There are certain bumps I go over each day on the way to work which without fail produce the same noise every damn time.[/color]
Quantum, MBR and EliseParts have all been helpful in trying to figure this out so I can't really fault them but I kinda wish I got the Nitrons.
Anyone else with Zeros got any noises? I know one other member had a set of Quantums fitted a few months ago and they had to go back to Quantum because they had the same 'chirping' that I had but I've not been able to find out from him if he has the other 2 noises I've got.
I figured on the track you probably wouldn't hear the 3rd noise because you don't tend to get bumps like that, but the sqeaking is so obvious.
I'm due to take the car down to Quantum so they can hear the noises I am referrring to, but I have to take time off work to go there so I've not yet been able to go. All in all a bit of a hassle, can't say I'd recommend the zeros to anyone at the moment, for £960 plus the money I've had to spend at MBR it's not been a good investment
Edited by james4563, 06 April 2017 - 03:34 PM.
