Ati Serpentine Super Dampers
Posted 20 March 2017 - 05:45 PM
Posted 20 March 2017 - 05:53 PM
Posted 20 March 2017 - 06:46 PM
The first question I'd ask myself is "is there actually a problem that requires this part"?
Posted 20 March 2017 - 07:22 PM
Posted 20 March 2017 - 07:50 PM
Posted 20 March 2017 - 07:51 PM
Yep it is but he has underdrive version.Is this what lee has
Posted 20 March 2017 - 08:56 PM
Edited by mige, 20 March 2017 - 08:58 PM.
Posted 20 March 2017 - 09:21 PM
crankshaft vibrations/harmonics at high rpm's...
From ZZP: To be able to spin the engine safely above 7200rpm, you will need to add 82# valve springs, and when you want to go above 7500rpm and still be safe I would recommend our neutral balance shafts and upgraded ATI balancer. The ATI damper is a very important mod, we have broken many crank keyways using the factory balancer/crank pulley, the ATI unit has cured that problem.
I've seen one broken oil pump gear and that engine had the stock balancer replaced by an "upgraded" lightweight alloy version...
Posted 20 March 2017 - 10:18 PM
Posted 20 March 2017 - 11:12 PM
Been thinking about this as well i bought mine of Richard need to work out what boost i will be running with the pulleys i have .
Posted 20 March 2017 - 11:42 PM
you got link for ati parts
Posted 21 March 2017 - 06:46 AM
Posted 21 March 2017 - 07:58 AM
I've been reading about these forged oil pump gears and was wondering where do you buy them from?I have light alloy part before it brokes exactly where oil pump gear sits Oil pump gears was ok but i install forged oil pump gears also no problems since 3 years with harrop
Posted 21 March 2017 - 08:16 AM
I have the GM Racing oil pump gears in mine, so does MaxR
The production oil pump gears can crack with an aftermarket crank pulley fitted.
Posted 21 March 2017 - 09:02 AM
Posted 21 March 2017 - 09:08 AM
Posted 21 March 2017 - 09:11 AM
Posted 21 March 2017 - 10:19 AM
So these are a direct fit to the Saab b207 oil pump cover/housing?Sorry wrong informarion isend you link where i buy it from http://www.smgmotori...om/categories/4
