You could consider reducing your front spring rates after installing a stiffer front ARB, this is both theoretical (and in my experience also true in practice, albeit my car is quite different to most).
Bear in mind the OEM bar exerts 50 lb/inch (when it has new drop links), the 4 possible settings on the Elise Parts jobby that I have are 250 Lb, 200 Lb, 165 Lb, 140 Lb. So even on it's lowest setting (which is what I have it on) it's 3 times more powerful than OEM and thus indirectly increasing your front spring poundage when cornering.
I found that every time I dropped my front spring poundage my understeer decreased, I even went as low as 225 Lb front springs for a while, but have since increased these to 275 Lb just to stop the front of the car from bottoming out so much. My rear springs are 450 Lb BTW.
I've experimented with about 5 different front spring poundages and 3 of the ARB settings, so I offer this info from practical experimentation and testing on my own VX.
HTH.
Edited by Nev, 17 April 2017 - 01:38 PM.
