Led Headlight Bulbs
39 replies to this topic
#1 Willovrs
Willovrs
  • 216 posts
Posted 25 April 2017 - 07:40 PM
Hi, Anyone fitted any led headlight bulbs? Similar to this - https://www.ebay.co....tm/391749041928 Wondered whether they would - A) actually work B) not catch fire C) actually fit D) give out decent light Thanks Sent from my iPhone using Tapatalk
#2 Strugs
Strugs
    World's #1 cheese fan
  • 3,008 posts
Posted 25 April 2017 - 07:57 PM
They'd be less of a faff than HIDs if they work!
#3 Tareim
Tareim
  • 80 posts
Posted 25 April 2017 - 09:23 PM
This video might be of some use
looks like the LEDs don't really have a beam pattern so might cause issues
#4 martinroger
martinroger
  • 461 posts
Posted 25 April 2017 - 09:35 PM
Following this out of curiosity.
#5 Willovrs
Willovrs
  • 216 posts
Posted 25 April 2017 - 11:49 PM
Be interested if anyone had tried these Sent from my iPhone using Tapatalk
#6 fezzasus
Posted 26 April 2017 - 06:15 AM
Someone has: http://www.vx220.org...d-and-reviewed/
also see this http://www.vx220.org...rest/?p=1859226 (note this was comparing a projector made for an LED bulb vs a projector made for a xenon bulb, so represents a best case comparison)
#7 Willovrs
Willovrs
  • 216 posts
Posted 26 April 2017 - 06:47 AM
Someone has: http://www.vx220.org.uk/forums/topic/143567-led-headlights-fitted-and-reviewed/   also see this http://www.vx220.org.uk/forums/topic/117604-replacement-headlights-gauging-interest/?p=1859226 (note this was comparing a projector made for an LED bulb vs a projector made for a xenon bulb, so represents a best case comparison)
Cheers Sent from my iPhone using Tapatalk
#8 fezzasus
Posted 26 April 2017 - 06:59 AM
Final point. LEDs are fitted to modern cars for two reasons:
Much more energy efficient than xenon which results in less alternator loading and therefore better fuel economy
Much more flexible headlight design due to smaller packaging
in a retrofit application, these points don't matter and I would still recommend xenon as a superior bulb type
#9 martinroger
martinroger
  • 461 posts
Posted 26 April 2017 - 07:22 AM
Thanks Fez (as usual)
#10 Haston
Haston
  • 198 posts
Posted 26 April 2017 - 08:44 AM
Been looking at these to....might actually take the plunge and buy them.
#11 oakmere
oakmere
  • 2,143 posts
Posted 26 April 2017 - 10:12 AM
I was thinking about some of these for main beam as beam pattern is not such a problem and no flash issues of HID. Don't think I would risk them in the dipped beam.
#12 Haston
Haston
  • 198 posts
Posted 26 April 2017 - 11:04 AM
LED's shouldn't be a problem in dipped beam as they are in the projector.
It's only in reflectors that you get blinding issues with HID's
#13 fezzasus
Posted 26 April 2017 - 11:29 AM
Not entirely correct.
Halogen projectors have a different cut off profile to xenon, which means more dazzling when retrofitted with a different type of bulb. The projector dish and lens are also sized to the wavelength of the bulb, so changing bulb type means poorer focus, more dazzling and worse cut off.
#14 oakmere
oakmere
  • 2,143 posts
Posted 26 April 2017 - 06:34 PM
Might get some for the H7 main beams. I have never changed the main beam bulbs. They are now over 12 years old so I have got my money's worth 😆
Edited by oakmere, 26 April 2017 - 06:35 PM.
#15 H1 HWK
H1 HWK
  • 1,009 posts
Posted 26 April 2017 - 08:28 PM
Hi All, I ordered some H7's to go in the main beam a few weeks ago (running HID's as dip beam which I find great and the projectors seem to give a really tight beam cut off, so don't believe these cause unnecessary dazzle). Will make an effort to fit them tomorrow. My reasoning was that the dip beam provide plenty of light so if the LED's don't produce much extra it's not the end of the world, and they will flash up instantly so you don't get the start up lag that is a negative effect on the HID's Will try and feedback in a few days.
#16 Willovrs
Willovrs
  • 216 posts
Posted 26 April 2017 - 08:39 PM
If you could post some photos of fitment and what they look like on that would be awesome Sent from my iPhone using Tapatalk
#17 Strugs
Strugs
  • 3,008 posts
Posted 26 April 2017 - 09:15 PM
I've currently got HIDs which have a nice crisp cut-off, why would LEDs be any different (in our application)?
Edited by Strugs, 26 April 2017 - 09:16 PM.
#18 martinroger
martinroger
  • 461 posts
Posted 26 April 2017 - 11:01 PM
LED's shouldn't be a problem in dipped beam as they are in the projector.   It's only in reflectors that you get blinding issues with HID's
  Not entirely correct.   Halogen projectors have a different cut off profile to xenon, which means more dazzling when retrofitted with a different type of bulb. The projector dish and lens are also sized to the wavelength of the bulb, so changing bulb type means poorer focus, more dazzling and worse cut off.
I suspect it has to do with the shape of the light source being quite different from halogens or HIDs which then fafs up the cut-off! I had that in the motorbike when I tried leds in the projectors.
#19 fezzasus
Posted 27 April 2017 - 06:09 AM
Different wavelength light leads to different diffraction angles through the lens of the projector.
BTW, the cut off for a projector designed for xenon bulbs is much better than the projector used in the vx.
#20 Haston
Haston
  • 198 posts
Posted 27 April 2017 - 06:19 AM
The cot off line I currently have with my HID's are crisp and never had any issues with dazzling.
H1's ordered now to fit the projector.
