Vx Turbo Stack Erratic Reading? Sensor?
4 replies to this topic
#1 glitch
glitch
  • 275 posts
Posted 19 May 2017 - 11:17 AM
Hi guys,
while driving to the MOT the other (yes it finally passed!!!) I noticed some erratic behaviour of the temperature reading on the instrument cluster.
Temps were fluctuating going up to 82-82, then rapidly dropping a few degrees at a red light, the up again and down again and it went like that for a while. Driving home from the MOT temps were stedy at around 84-86 C.
On my previous Rover engined Elise this was a typical behaviour of the coolant sensor being on its way out.
How is it on the Turbo normally?
I know before I got the car Matt Bentley who was troubleshooting some issues replaced the coolant sensor, but replaced with a used one so not unlikely it is on its way out.
Where exactly is the temp sensor located on the turbo, and would someone have the parts number / point me to where I can get one. I have an Opel dealershop close to work so I could pop in and get an OEM one unless they are ludicriously expensive.
Any pointers for swapping it would be appreciated to. I will be doing the rad shortly so planned on swapping the sensor at the same time (given that is the usual remedy).
Thanks!
#2 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 19 May 2017 - 02:35 PM
From memory 85-86 was normal on it, used to see 103 coming off track..
I had the sensor on top of the charge cooler fail once, but that made the temp gauge go to 999c
Wouldn't worry about it
#3 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 19 May 2017 - 02:36 PM
If you have changed the rad, make sure no air is trapped, that can sometimes be the issue
#4 glitch
glitch
  • 275 posts
Posted 19 May 2017 - 06:40 PM
Not changed the rad yet. Interesting about the chargecooler sensor, wasn't aware there was one? What does it do? And how is it connected to the stack?
#5 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 19 May 2017 - 07:02 PM
its the MAP sensor, I changed it once then the temp gauge was reading funny temps even from cold
