Fuel Learn - Tips And Tricks - Obd Tuner
#obd tuner
33 replies to this topic
#21 FLD
Posted 05 July 2017 - 08:33 PM
I spent quite some time adjusting the tickover and throttle enrichment (to get better response).  It's not difficult to do, read the manual carefully.  If you save off the base map you can play and then always revert back if needs be.  It is frustratingly slow when compared to mapping on the rollers but it's not hard to do.  Just try!
#22 oakmere
oakmere
  • 2,143 posts
Posted 05 July 2017 - 10:46 PM
The ignition learn only removes ignition advance so no chance of increasing power. It is a safety feature to make sure there is no knock. Fuel learn then ignition learn. That is it for a safe map. Do these two then decide if you feel further improvements are required.
#23 Firthy
Firthy
  • 576 posts
Posted 06 July 2017 - 08:26 AM
Really appreciate all the tips guys.... Went out for a couple of hours last night at 22.00
https://goo.gl/photo...FZCzVrNvZjzha5A
https://goo.gl/photo...76zgmYQ7doi25KA
Didn't hit all the columns green but hopefully the session was good enough.
Cars pulling like a train now and feels even smoother
So the general consensus is do a knock ignition learn then I should be safe to rag it all day on Monday?
Edited by Firthy, 06 July 2017 - 08:31 AM.
#24 Firthy
Firthy
  • 576 posts
Posted 06 July 2017 - 08:43 AM
I must say I've had no issues regarding the software I'm using a PC on windows 10 its been rock solid went for a 2 hour drive processed the table no problem. Saved to ECU - calibration permanent and engine switched off.
Edited by Firthy, 06 July 2017 - 08:43 AM.
#25 oakmere
oakmere
  • 2,143 posts
Posted 06 July 2017 - 08:56 AM
A very good fuel learn 👍 After I have processed and saved the fuel learn to the ECU. I always reconnect the PC to the ECU and check the main fuel table comparing with the previous map (base map in your case) to check the changes have been made. Just the ignition learn now which is pretty much the same process as a fuel learn.
#26 Rob3770
Rob3770
  • 109 posts
Posted 07 July 2017 - 04:10 PM
I had mine set on the dyno, (more to find out what I had power wise) but I will be coming to have it done by the expert especially if I'm going to be racing with him soon :-)
#27 Firthy
Firthy
  • 576 posts
Posted 08 July 2017 - 01:27 PM
Kind Sir's your help needed again please.
Does this look okay? If I'm reading it correctly there seems to be some knock higher up the rev range?
Didn't apply this one as I went over a few bumps what do we think? Worried that as my suspension is stiff its picking up false knock?
 https://goo.gl/photo...zi5LE7xhAQd2DU8
Edited by Firthy, 08 July 2017 - 01:29 PM.
#28 smiley
Posted 08 July 2017 - 03:51 PM
When you pick up flase knock, chance is small that it is at the same place.
So compare multiple logs before making knock specific changes.
Edited by smiley, 08 July 2017 - 03:51 PM.
#29 Firthy
Firthy
  • 576 posts
Posted 08 July 2017 - 04:15 PM
Thank you thank you..... Okay great will do.... is it normal for the power delivery to be less instant when its hot?
Car feels a little laggy
To go back to the original do I just load the last fuel learn?
Edited by Firthy, 08 July 2017 - 04:16 PM.
#30 smiley
Posted 08 July 2017 - 06:31 PM
Yes intake temp matters. Over 57 and ecu starts taking back ignition. Next to warm inlet air having less oxigen thus less efficient burning. Both causes less power.
#31 Firthy
Firthy
  • 576 posts
Posted 08 July 2017 - 07:07 PM
Okay found out the issue.... https://goo.gl/photo...3kcVsA9QZWP4pCA
The catch tank pipe got stuck on the vacuum pipe resulting in no boost... moved this out the way and she back to normal.
Just worried I damaged the engine as there appeared to be some knock whilst it wasn't allowing boost to build!
Edited by Firthy, 08 July 2017 - 07:07 PM.
#32 oakmere
oakmere
  • 2,143 posts
Posted 08 July 2017 - 11:12 PM
Just process the knock learn for now and it will remove some ignition advance. You will have a safe map for now. Don't worry about 4 degrees KR the engine will be fine.
#33 Firthy
Firthy
  • 576 posts
Posted 09 July 2017 - 09:37 AM
Thanks Oakmere looks like I'm reading the knock wrong.... Did a log again plus sent my calibration to peter and he's happy, thank you all for your advise
Edited by Firthy, 09 July 2017 - 09:37 AM.
#34 CHILL Gone DUTCH
Posted 09 July 2017 - 01:20 PM
unless you  have done something seriously wrong the ecu will protect you,
Edited by CHILL Gone DUTCH, 09 July 2017 - 01:21 PM.
