Itb Running Lean And Engine Risk
20 replies to this topic
#21 Nev
Posted 13 July 2017 - 05:30 AM
However, if you unplug the o2 sensor that should richen things up at bit. Another way to make it richer is to lower the airflow a kg per hour and put the TPS back to idle voltage. That will significantly make it richer across the band. I did this when I was worried about lean as a temporary measure and my exhaust temp went down a lot.
Good insight.
