https://www.kamracin...t-calipers.htmlGo on then, how much for a set ?42s don't cut it on track. I was surprised how well the CL8s worked from cold. I'd have no problem using them on the road (apart from the expense
Brake Pads - Rs42 Vs Rs14 + Similar
#21
Posted 25 August 2017 - 05:09 PM
#22
Posted 26 August 2017 - 11:25 AM
UK distributor is Fortuna Moto in Redditch, 01527332194, 4060 and 4415 were 140 and 135 respectively, £339 with P+P and VAT. I came to them via a deal through the race series, but I expect he will treat any enthusiast the same and may be amenable to a GB
#23
Posted 27 August 2017 - 08:06 PM
#24
Posted 28 September 2017 - 09:55 AM
So, I bought some RS14s off Captain Vimes (super cheap, thanks Kev!) and tested them on track yesterday.
Stopping power was great and they didn't seem to fade... however I got a lot of rumbling and judder all day. It was particularly bad when light braking (e.g. when you get stuck behind a Caterham with no mirrors). Never lost the brakes or anything but it does knock your confidence. Is it normal?
#25
Posted 28 September 2017 - 11:01 AM
#26
Posted 28 September 2017 - 08:50 PM
As above I always had issues with the RS14s and rumbling/judder but they always hauled the car up lap after lap.RS14's ... when the discs got hot I had rummbly brakes - possibly from pad deposits. Brake coolers and grooves discs have helped but not solved this.
#27
Posted 29 September 2017 - 07:57 AM
Hmm, hopefully it won't get any worse, will try RC6 next time!
#28
Posted 29 September 2017 - 08:14 AM
#29
Posted 29 September 2017 - 10:08 AM
I don't think it's primarily the pads alone It's more likely to be what pads you have used before on the same disc
I put fresh front discs on, but the rears have had RS42s (and 1144s in the past). Maybe worth a £50 punt and change rear discs...
#30
Posted 02 October 2017 - 07:09 PM
#31
Posted 17 December 2017 - 12:27 PM
FIr what ever technical reason there is I also found the same when moving to one pad to RS14 used fresh discs on with only RS14 pads and no issues since
This was exactly right thanks chill.
I stuck my old RS42s on the back and did a track day (so the front is RS14 with fresh discs, back 42 old discs), and I've got much less rumbling. So I'll be less of a pikey next time I think...
#32
Posted 17 December 2017 - 01:27 PM
OK, so spoke to Matt Bentley and he recommended PF11s or RS14s.
RS14s are now £400 on Eliseparts
whereas Performance Friction are around £300. Anyone have any experience with these, or know an alternate (cheaper) supplier?
These Lotus shops just take the p*ss on prices.
I bought some RC8 pads for my Porche front brake setup and they were just £300 (inc VAT). Not only are they cheaper, they are +80% larger surface area, so last a lot longer.
RC8 is pretty good, makes my car squirm a hell of a lot as I think the wishbones and bushes take too much strain (possibly also caused by the extra rubber).
Edited by Nev, 17 December 2017 - 01:56 PM.
#33
Posted 17 December 2017 - 04:09 PM
#34
#35
Posted 20 December 2017 - 09:33 AM
But they are not cheap and only just last over 2 track days
Tried the CL RC6 Endurance ones? Might give them a go next year.
#36
Posted 20 December 2017 - 01:01 PM
Endurance pads are no good to me I need instant braking power, The RS14 have given night and day improvements for me with instant biteTried the CL RC6 Endurance ones? Might give them a go next year.But they are not cheap and only just last over 2 track days
