Lamba/oxygen Sensors (Turbo)
Posted 31 August 2017 - 09:09 AM
Posted 31 August 2017 - 09:11 AM
what is the actual error code you see?
Posted 31 August 2017 - 09:14 AM
Hi
I have some good used OEM sensors, £18 each plus postage
Posted 31 August 2017 - 09:20 AM
the sensors will age and react slower , more likely wiring and plug damage will occur from modifications.
only the first lambda does anything useful and will trim the fuel adjustments over short and long durations
Posted 31 August 2017 - 04:01 PM
Posted 31 August 2017 - 06:13 PM
Posted 31 August 2017 - 07:53 PM
Posted 01 September 2017 - 08:17 AM
I just sorted out a turbo with oxygen sensor fault triggered, voltage was fixed at 40mv - new one fixed it. Sent from my SM-G903F using Tapatalk
Same , had a client in for a remap , and that was constant low voltage , gave them a spare lambda to fit.
Posted 06 September 2017 - 05:25 PM
Received the new sensors today. Went to replace, Precat came out without much trouble. Needed a hammer and a lever for the rear one. It came out looking like this.
Anybody had to overcome this. It's fair to say the thread will be shot. I don't know where to go from here.
Posted 06 September 2017 - 06:11 PM
First buy a thread cutter and try "cleaning" the existing thread, you may find you can clean it up well enough for the new sensor to bite in adequately.
If the boss thread is really buggered then a solution will be to take the car to an exhaust fabricators and ask them to cut it out and re-weld in a new one.
Edited by Nev, 06 September 2017 - 06:28 PM.
Posted 07 September 2017 - 11:08 AM
generally as the exhaust is stainless and hard metal you should be able to re-tap the thread. Try a local garage they might be kind enough to lend you a tap as this happens all the time.
Edited by Johnboyhgt, 07 September 2017 - 11:15 AM.
Posted 07 September 2017 - 11:20 AM
Just like i had to do, a picture tells a thousand words.
New ones here, just use a lubricant, engine oil would do :https://www.rapidonl...a4aAmIyEALw_wcB
Edited by Johnboyhgt, 07 September 2017 - 11:27 AM.
Posted 07 September 2017 - 11:53 AM
So I think I might cry Received the new sensors today. Went to replace, Precat came out without much trouble. Needed a hammer and a lever for the rear one. It came out looking like this. Anybody had to overcome this. It's fair to say the thread will be shot. I don't know where to go from here.
Looks like you are in luck, looks like its trashed the sensor thread and not the boss... M18 thread cleaner/tap and away you go. Although I will caveat that with, be careful with filings calling into the exhaust, but as its post cat you "should" be ok.
Decent new sensors should have a light dab of anti-sieze grease on the threads, if not then carefully apply the tiniest spot of copperslip of the like to prevent it happening again. Word of caution again, TINY bit!!! oils destroy the sensor bit, so things like using pentrating oil or shite like wD40 on a sensor with the view to using the sensor again is a bad move etc.
Posted 07 September 2017 - 06:35 PM
Posted 07 September 2017 - 08:08 PM
Sorted the thread problem. Installed the new sensors. Took her out for a run and.....problem persists. Next thing to try?
Find out the exact Pxxx code(s) you are getting and look them up and let us know.
Edited by Nev, 07 September 2017 - 08:25 PM.
Posted 08 September 2017 - 12:38 AM
disconnect the maf and take it for a drive.... It's only a 2 second job..
Posted 08 September 2017 - 07:53 AM
Posted 08 September 2017 - 08:08 AM
Any suggestions for OBD apps that will give me such information? I'm running Dash Command (which wasn't free) for Iphone which dosent appear to be thorough enough to give me The codes, just what ive posted above.
Failing that I'm going to invite an Android friend over, see if we can find out.
Posted 08 September 2017 - 09:03 AM
You can buy a dedicated ODB2 code reader off eBay for about £15 - well worth it for the VX and any other cars you get. Try and get one that "claims" to work well of Opels.
I use mine to reset my codes and dash lights prior to MOT which saves me a fortune!
I'm sorry the new lamda's didn't fix your problem, seems strange based on what your app showed (red dots for the lambdas).
Edited by Nev, 08 September 2017 - 09:09 AM.
