Lamba/oxygen Sensors (Turbo)
21 replies to this topic
#21 slindborg
Posted 08 September 2017 - 10:04 AM
Not sure if its the same on the lardy turdo, but the N/A definately has two connectors near the post cat sensor, one is for the post cat and the other does, well, nothing... makes sure its plugged into the right place, although postcat wont cause running problems
#22 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 08 September 2017 - 06:40 PM
Had a chat with Branagorn, he has a cylinder misfire fault so given the usual advice about coils and plugs, plugs being the cheaper option to try first. But forgot to say check your coil rubbers for corrosion, so there you go check those too ! Sent from my SM-G903F using Tapatalk
