sometimes the geo has as much to do with things as the springs/dampers too.
e.g. I had a fairly hard sprung/soft damping setup on mine and it would grip forever then "snap" and it was more or less unrecoverable, I then changed the reat toe links and had it all setup to something akin to halfway between the fabled 340R road and track settings.... same springs and dampers, it would let go far sooner than before, but it was recoverable, plus way less scary in the wet
iirc when Randy was explaining things, the springs dont "really" control the body roll persay, but the dampers do. Hence why some of the setups now have what looks to be fairly hard springs, sod all damping and then an apparently stiff ARB.
There is also some anecdotal stuff around regarding going very soft on the springs, soft on damping and higher on the ARB to prevent skittish behaviour but permit very very compliant ride, e.g. good on the road (and 't ring)
