Failed Mot Abnormally High Emissions
37 replies to this topic
#21 Andy_VX
Andy_VX
  • 2,050 posts
  • Interests:Cars, Boats, F1, Cycling, Home Cinema, Music.
Posted 15 September 2017 - 12:13 PM
Sorry Alex, didn't see your reply, that's very good of you thanks. Let me know your paypal address and i'll send you some dosh for postage. You still got my address?
#22 chickendippers
chickendippers
  • 488 posts
Posted 15 September 2017 - 01:30 PM
No problem at all mate, ping address your address when you can please. Don't worry about postage
#23 phippsy
phippsy
  • 472 posts
Posted 16 July 2018 - 06:52 PM
Hi Andy,
My car just failed its MOT due to high emissions. Did you find out what was causing your issue out of interest?
#24 Nev
Posted 16 July 2018 - 07:55 PM
Hi Andy,
High emission of what, precisely? Bear in mind you may have failed on a different emission to the OP....
Edited by Nev, 16 July 2018 - 07:56 PM.
#25 fezzasus
Posted 16 July 2018 - 08:05 PM
Hi Andy,
No need to be pedantic in this case, a standard 2 way catalyst converts both HC and CO into CO2 so you can't elucidate a failure mode by knowing if it's CO or HC. Either or both could mean the cat has failed, or some failure is leading to overfueling and overwhelming the catalytic converter
#26 phippsy
phippsy
  • 472 posts
Posted 18 July 2018 - 08:04 PM
Hi Andy,
Cheers Fezz,
Im currently still on the Dutch base map so im guessing that may have something to do with overfueling
#27 CHILL Gone DUTCH
Posted 18 July 2018 - 08:56 PM
It won't be to do with the map
AS THAt only gets used on high loads
On low loads it used the lambdas
So could be CAT
Or lambdas
#28 phippsy
phippsy
  • 472 posts
Posted 18 July 2018 - 09:03 PM
So could be CAT
Or lambdas
Could it possibly be an exhaust leak? Sounds like a pita whatever it is.
Fail was 'exhaust lambda reading after 2nd fast idle outside specified limits 8.2.1.2©
Max 1.030
Mine was 1.049 & 1.043
#29 CHILL Gone DUTCH
Posted 18 July 2018 - 09:06 PM
Yes
#30 phippsy
phippsy
  • 472 posts
Posted 18 July 2018 - 09:22 PM
#31 Exmantaa
Posted 18 July 2018 - 09:58 PM
If you have OBD, make a log from the O2 sensor signals. (warm engine)
#32 Andy_VX
Andy_VX
  • 2,050 posts
Posted 26 February 2019 - 10:12 AM
Please excuse my ignorance but i'm trying to learn more about open / closed loop to diagnose the emissions fault on my VX. I' took it to a garage this morning and they've informed me that there's no reading from the pre-cat sensor 1 lambda (I replaced this with a genuine new Bosch one) so I assume the guy that mapped it has by-passed this for some reason, what would be the benefit of doing this?
My understanding of the system:
Closed loop should operate when the engine is at idle or at a constant cruising speed, this is when the ECU is taking an actual reading from lambda’s as to the AFR and adjusting as necessary.
Open loop is the state where the engine is under heavy load (acceleration) or when the engine is under no load (overrun). In this open loop state the engine by-passes the lambda sensors and enriches the mixture or weakens it depending on throttle position.
If a mapper was to by-pass the closed loop the engine would inherently run much richer at idle as it wouldn’t know what the AFR was and would enrich the mixture automatically, does that sound about right?
#33 siztenboots
Posted 26 February 2019 - 10:15 AM
sensor 1 is the main fuelling sensor , if you have 0 volts then its gone very lean or loom failure
#34 Nev
Posted 26 February 2019 - 10:53 AM
Why not ring your mapper up and ask him directly, better than us guessing what he might or might not have done.
Edited by Nev, 26 February 2019 - 10:54 AM.
#35 Andy_VX
Andy_VX
  • 2,050 posts
Posted 26 February 2019 - 11:00 AM
Yes I have spoken with the mapper, he's been very helpful but i'm just trying to get an understanding of how it works for my own piece of mind.
They've informed me that they do not disable O2 sensor during mapping and that it may be a loom issue. I need to find a wiring diagram now so i can check that, if anyone has one that would be much appreciated.
#36 siztenboots
Posted 26 February 2019 - 11:06 AM
if you are getting 0 volts , then I would check the grey plug on the loom , pin 6 for 12v supply , the plug is between both lambda plugs on the loom
#37 Andy_VX
Andy_VX
  • 2,050 posts
Posted 26 February 2019 - 11:10 AM
Excellent, thanks very much i'll check that tonight.
#38 siztenboots
Posted 26 February 2019 - 12:04 PM
picture to help find it , pin 6 is the red-white 2.5mm thick wire , its common to both lambda and few others
