Help-Steering Play!
Posted 28 September 2017 - 10:42 PM
Posted 28 September 2017 - 10:56 PM
Posted 28 September 2017 - 11:06 PM
There are no trays that cover any part of the steering so don't go there again.
Get your head under the dash and have a look at the UJs. See if the bottom of the column as it goes through the bulk head moves exactly as you wiggle the wheel. If not then see which UJ the play is in. If it does then jack it up and see if the play is in the track rod ends.
If its not there then it's in the ineer joint cups or the pinion were the column meets the rack.
Posted 29 September 2017 - 07:16 AM
Get a new garage!
All I would add to the young lad above, is that if you lack the night vision of a trained killer, when inverted in the footwell, I slide my finger down the potentially loose parts of the bottom UJ while rocking the wheel. I can feel the movement better than I can see it (which I often can't).
Posted 29 September 2017 - 07:33 AM
Mine had this mentioned for the first time this past MOT. After a quick look I couldnt find anything wrong so I did some searching on here and remembered about the steering rack bush issue that makes a knocking noise but doesnt cause any issues. I think thats what they heard on mine and mentioned it as steering play. Mine defo has the steering rack knock noise but no adverse effects or excessive play.
Posted 29 September 2017 - 08:14 AM
Giggedy
Posted 29 September 2017 - 09:38 AM
Posted 29 September 2017 - 10:54 AM
Posted 29 September 2017 - 11:16 AM
Yes you are correct. Chances are your current ones just need tightening up rather than replacing though.
Posted 29 September 2017 - 11:36 AM
Something to be aware of - I bought that kit, but in my column the 'joining rod' is not welded to the bottom joint. I can't recall how it works, but I think the top joint has a larger aperture to accommodate the steering column (steady Steve!), so only fits at the top. If your bottom UJ is not welded, that kit may not suit.
I may however be talking bollox.
Posted 29 September 2017 - 11:42 AM
Posted 30 September 2017 - 10:17 AM
Posted 30 September 2017 - 11:31 AM
Posted 30 September 2017 - 04:24 PM
The car will tend to wander in the road. And will wander more the worse it gets.
Posted 30 September 2017 - 08:59 PM
Posted 30 September 2017 - 09:14 PM
did you sort it?
Posted 01 October 2017 - 09:13 AM
Realists answer-to me what would happen is the steering will fail and I'll have a serious crash! Ummm....just thinking back to the Porsche 911 I had for a whole month!! Sent from my SM-G955F using Tapatalk
Posted 01 October 2017 - 09:15 AM
Posted 01 October 2017 - 03:13 PM
