Airbag Replacement
30 replies to this topic
#1 VX DAVE
VX DAVE
  • 139 posts
Posted 28 December 2017 - 08:48 PM
This might be a long one....
I bought my vx and was told that the airbag light was on due to the aftermarket seats which were installed.....
was told pre tensioners not connected
I have been getting to know my car and I have discovered that my airbag is not even connected..   no idea why
I would obviously like to connect my airbag but I am concerned,    back in 2009   the car was cat D     supposed to be cosmetic damage
where are the sensors which would activate the air bag
I don't want to plug the air bag in until I know the sensors are ok  (not about to activate the bag)
any help / advice regarding this - much needed and appreciated
Dave
#2 Nev
Posted 29 December 2017 - 07:52 AM
The airbag has it's own ECU somewhere. If it's been triggered it might possibly be reprogrammable, but I don't know anyone who's done it.
#3 vocky
Posted 29 December 2017 - 08:59 AM
the vx220 does not have seat pretensioners, it has sensors built into the actual seatbelt assembly. You should see a yellow plug connected to the seatbelt reel (all the airbag system plugs are yellow).
So either the seatbelt is duff or it's disconnected.
The airbag ECU sits underneath the dash, behind the starter button. If it has been activated it's dead, fit a replacement.
#4 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 29 December 2017 - 09:01 AM
Airbag ecu is under yhe dash top right in the center. If you are concerned about its state then contact Elizp987 through the site, she is sure to have one in good condition. You must disconnect the battery for 10 minutes before changing the ecu. Sent from my SM-G903F using Tapatalk
#5 The Batman
Posted 29 December 2017 - 11:53 AM
I think I have a spare ecu
#6 VX DAVE
VX DAVE
  • 139 posts
Posted 29 December 2017 - 02:57 PM
So, if the air bag ecu has triggered,   and I connect a new air bag - will it activate the air bag
or is the signal from a triggered ecu a one time thing
I assume a code reader wont turn off the air bag light either...
Is there any way other than crashing, to find out if the air bag ecu is working or not ?
Edited by VX DAVE, 29 December 2017 - 03:06 PM.
#7 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 29 December 2017 - 03:03 PM
A code read is a good idea and will tell you a definitive answer to your question. Sent from my SM-G903F using Tapatalk
#8 vocky
Posted 29 December 2017 - 03:13 PM
once it's fired the airbag the Airbag ECU is dead, get a code reader and see what the codes are. There might be nothing wrong with the ECU
#9 VX DAVE
VX DAVE
  • 139 posts
Posted 29 December 2017 - 04:09 PM
so if the ecu has fired and is dead - plugging in a new airbag, it wont deploy immediately
next question is, Op-com / Vaux-com        who and where - feel free to contact me via private message
Edited by VX DAVE, 29 December 2017 - 04:11 PM.
#10 ElizP987
ElizP987
  • 4,037 posts
Posted 29 December 2017 - 04:40 PM
hi
I have brand new airbag modules (ECU)'s and secondhand ones too.
I also have seatbelts with pre-tensioners if needed :)
#11 slindborg
Posted 29 December 2017 - 07:58 PM
So, if the air bag ecu has triggered,   and I connect a new air bag - will it activate the air bag   or is the signal from a triggered ecu a one time thing   I assume a code reader wont turn off the air bag light either...     Is there any way other than crashing, to find out if the air bag ecu is working or not ?
In order to trigger the airbag, you need to have one hell of a smash that frankly the airbag is least of your worries :lol: :(
#12 VX DAVE
VX DAVE
  • 139 posts
Posted 29 December 2017 - 10:06 PM
okey dokey, I am happier now - I recon I can just plug my airbag back in and I expect the airbag light to stay on
op com being the only way to switch it off
#13 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 29 December 2017 - 11:13 PM
Correct. If the light stays on then code read then post here with the fault codes for more help. Sent from my SM-G903F using Tapatalk
#14 ElizP987
ElizP987
  • 4,037 posts
Posted 30 December 2017 - 02:10 PM
the airbag ECU's are also known to fail :)
#15 VX DAVE
VX DAVE
  • 139 posts
Posted 30 December 2017 - 03:29 PM
I have got my code reader, I will see what shows up
I don't currently have an EML illuminated, but there may be some stored codes.
#16 VX DAVE
VX DAVE
  • 139 posts
Posted 30 December 2017 - 09:11 PM
So, here we go, no DTCs
MIL status = off
4 stored codes came up
P 0201 / 0203 / 0202 / 0204
Injector circuit / open cylinder   1  3  2  4
cleared the 4 codes
MIL status = off
#17 VX DAVE
VX DAVE
  • 139 posts
Posted 30 December 2017 - 09:14 PM
This plug, looks to me  as though it has seen some heat
inside the back of my airbag    it is green plastic - on this particular airbag it looks OK  (ie not melted)
Edited by VX DAVE, 30 December 2017 - 09:16 PM.
#18 slindborg
Posted 30 December 2017 - 09:50 PM
You need an opcom to read the airbag codes iirc
#19 VX DAVE
VX DAVE
  • 139 posts
Posted 30 December 2017 - 10:21 PM
That's what I thought
Are we allowed to discuss opcom
I read somewhere that the software is freeware - is there a trusted source ?
#20 The Batman
Posted 30 December 2017 - 11:05 PM
First rule about opcom... dont talk about opcom :lol: It is freeware Im sure someone has a link, run a virus check first :lol:
