Eltech Stuff
interesting bits
36 replies to this topic
#1 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 31 December 2017 - 10:39 AM
After all the years of modding my vx, somehow never heard of Eltech. Had a good look today and they have a lot of interesting bits for Vx's and Lotus cars.
Some nice seats, carbon bits, very interesting big rear diffuser and lots of other bits.
Sadly not a lot for my car.
Martin S
#2 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 31 December 2017 - 11:51 AM
Had the Eltech diffuser on mine for a couple of years now
#3 Ormes
Ormes
  • 4,612 posts
Posted 31 December 2017 - 01:59 PM
Splitter for me at some point in 2018... not managed to get man-maths to work on the seats yet :)
#4 oblomov
oblomov
    oblomov
  • 3,885 posts
  • Interests:Mumblers
Posted 31 December 2017 - 02:00 PM
Just bought an Eltech diffuser on offer, should be here mid January.
#5 ianrm
ianrm
  • 11,097 posts
Posted 31 December 2017 - 08:17 PM
I have a front splitter on order. Their delivery time is not the quickest though.
#6 C8RKH
C8RKH
  • 808 posts
Posted 31 December 2017 - 09:46 PM
Looks like nice stuff. I'm after the splitter, door cards and seats this year...
#7 C8RKH
C8RKH
  • 808 posts
#8 allsteel
allsteel
  • 445 posts
  • Interests:Winning lottery tickets,scantily clad women,real ale poured with a head,modified cars,great guitar playing.
Posted 01 January 2018 - 11:10 AM
Any links
#9 smiley
Posted 01 January 2018 - 11:16 AM
https://www.facebook...905817939439342
From what i hear so far, they seem to make to order, so be prepared to wait.
#10 oblomov
oblomov
    oblomov
  • 3,885 posts
Posted 01 January 2018 - 12:09 PM
Galloping senility strikes again, should have said Edel, and not Eltech and not diffuser but front splitter
http://www.ms-edel-c.../shop_frame.htm
I did look at the Eltech designs but preferred the Edel. It doesn't fit directly against the clam like most splitters but is spaced 2cm away.
#11 hairy
hairy
    Moonlander
  • 6,065 posts
Posted 01 January 2018 - 12:32 PM
I hadn't seen that splitter design before - looks good!
#12 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 01 January 2018 - 04:55 PM
  Galloping senility strikes again, should have said Edel, and not Eltech and not diffuser but front splitter http://www.ms-edel-c.../shop_frame.htm I did look at the Eltech designs but preferred the Edel. It doesn't fit directly against the clam like most splitters but is spaced 2cm away.
First I’ve heard of this company. I like the splitter design however, can someone with some knowledge of aero explain if it will actually work given the gap between the clam and the splitter? Will that make it more or less effective? Sent from my iPhone using Tapatalk
#13 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 01 January 2018 - 06:00 PM
itd be good at making drag that said, 95% of what anyone sells, or has bolted to their car is only good for asthetic puposes anyway.
#14 oblomov
oblomov
    oblomov
  • 3,885 posts
Posted 01 January 2018 - 07:10 PM
I certainly hope so, after all that's the whole point of a front splitter.  No doubt it will be mostly cosmetic though.  I doubt I'll achieve the speeds for any length of time required for it to have any real effect.
#15 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 01 January 2018 - 07:37 PM
lol wat? back to aerodynamics school mate
Edited by Doctor Ed, 01 January 2018 - 07:40 PM.
#16 oblomov
oblomov
    oblomov
  • 3,885 posts
Posted 02 January 2018 - 12:02 AM
Sorry, not with you, your point is?
#17 C8RKH
C8RKH
  • 808 posts
Posted 02 January 2018 - 09:56 AM
If I read that drawing correct the splitter creates negative cp (pressure co-efficient) just underneath it (the blue blob under the splitter appendage). I am assuming as I am clueless on these things that negative pressure will be lift!
Someone who knows their sh*t please put me straight.....
Edited by C8RKH, 02 January 2018 - 09:57 AM.
#18 Nev
Posted 02 January 2018 - 12:28 PM
I don't think any sort of splitter makes any difference to the aero unless the VX is low (by that I mean very low). I did some experimentation with a 3" all-around projecting plywood splitter and it made naff all difference until I lowered the car so that the splitter to ground clearance was below 9CM. At 7 CM clearance there was dramatic frontal down force (making the steering genuinely heavy) at speeds over about 90 leptons. However at 11cm (for reasonable road driving) my splitter made no difference, so I've taken it off.
In short the ride height is fundamental to making any sort of frontal down force on the VX220. And those OEM mini splitter things will make 0 difference as they are tiny, just there for looks as others have mentioned.
HTH.
Edited by Nev, 02 January 2018 - 12:36 PM.
#19 BadCop
BadCop
  • 96 posts
Posted 03 January 2018 - 07:55 AM
Nev, that is exactly what the books tell you and what my experience is so far.
Somewhere arround 60 mm there is a maximum ground effect that really makes the whole black magic of aerodynamics work.
Another really drastic effect shows up when you build some side skirts as low as possible:
Edited by BadCop, 03 January 2018 - 07:55 AM.
#20 Nev
Posted 03 January 2018 - 09:18 AM
@Badcop: Thanks for that, I had/have little in depth idea about aero really, I was simply using experimentation to see if/when a splitter would make any difference.
When I lowered the car down to the front coilover's bump stops the car could barely get over a coke can. Clearly you can't regularily drive like this for a couple of very good reasons, but it really was startling how much down force was generated. By about 110 leptons the steering became so heavy that I had to start using 2 hands to turn the steering wheel. The car was immensely planted like no other that I have ever driven. Sadly though, due to the road conditions we have I obviously couldn't leave it like that.
But for someone who just tracks/races their car then this info could be a great mod, though it's worth bearing in mind that this was in conjunction with a huge 10:1 chord wing on the rear.
I've been helping the Hertfordshire M.Sc team project VX220 that will be racing this year and they are doing something like this and some other carefully calculated aero mods, I am keen to see what they come up with, though they are regulated/limited by whatever rules there are. Maybe they can use side skirts and a profiled upside down low pressure wing under the chassis.
The team might even come up with something functional that could be made by Eltech or someone else as a road fitment for our cars.
Edited by Nev, 03 January 2018 - 09:26 AM.
