Trigger Wheel Question
trigger wheel crank
5 replies to this topic
#1 Vladimir
Vladimir
  • 111 posts
Posted 31 January 2018 - 12:07 PM
I want to use the LSJ crank which has the stroke of 86mm. Apparently, this crank has 60+2 teeth trigger wheel, while L61(z22se) trigger wheel is 6+1 teeth.
I see many were using the external trigger wheel setup, but why is it so? Is it not possible to replace the internal LSJ trigger wheel with custom made Z22SE trigger wheel?
#2 smiley
Posted 31 January 2018 - 12:14 PM
Most were doing that on a saab B207 enigne, being reluctant to swap that, as it requires opening the engine. I would say yes, you should be able to use a custom trigger wheel with Z22SE pattern on your lsj crank.
Wait for more info from Vocky the engine wizzard, or exmantaa who actually runs an lsj engine in his speedster. (though using hp tuners on stock triggerwheel)
#3 Rosssco
Rosssco
  • 4,185 posts
Posted 31 January 2018 - 01:03 PM
There's a few external trigger wheel options (although still not easy and off the shelf). Or there is an internal version that was done, but not sure who made them. The external is attractive as it means you don't have to strip down your new engine to install. I use an external wheel (Vocky's own design) and had no issues in 2 years while living outside.   See below for some one selling an internal /external wheel. https://z22se.co.uk/...nversion.29000/
#4 vocky
Posted 31 January 2018 - 02:14 PM
to replace the standard B207 (internal) trigger wheel you need to remove the crank from the engine, so not a two minute job. However not really a difficult job with the engine out of the car, just turn the engine upside down and remove the sump and craddle, etc.
A guy in the states makes an internal L61 trigger wheel, possibly Hitech do as well - not 100% sure.
I don't have any external trigger wheels and will not be sourcing any more either. I convert the B207 engines to a 2.2 with the z22se crank, steel rods and forged pistons.
#5 Vladimir
Vladimir
  • 111 posts
Posted 31 January 2018 - 02:21 PM
Thanks for the valuable feedback. Do you have a paricular reason for using the z22se crank?
My thoughts that with LSJ crank I will be able to incease the rpm limit much further and without harm for the engine than with the L61(z22se).
Vocky, do you have contact details of this person, who may supply custom trigger wheels?
#6 vocky
Posted 31 January 2018 - 02:34 PM
the z22se crank can safely rev to 7800rpm, I have never seen a power curve that has not peaked before 7800rpm on a z22se (or hybrid) na / sc / turbo. So probably no point it revving it higher.
USA thread - http://www.j-body.or...30&t=461530&p=8
the guy - http://www.j-body.or.../mdz24cavalier/
His website - http://www.ennotechd...m/products.html
Also tagged with one or more of these keywords: trigger wheel, crank
