Maf Sensors (Again!)
18 replies to this topic
#1 DX220
DX220
  • 326 posts
Posted 10 June 2018 - 09:58 PM
  1. To cleaner or not to clean?  :huh:
    1. If so, CRC cleaner or anything else?
  2. Bosch or HAAS  :huh:
#2 siztenboots
Posted 11 June 2018 - 08:58 AM
petrol / brake cleaner ( toluene)
its the oily crankcase vapours that coat everything in the tube
#3 Nev
Posted 11 June 2018 - 07:13 PM
Does the oily vapour manage to upstream to the MAF on the VXTs??
#4 DX220
DX220
  • 326 posts
Posted 12 June 2018 - 05:15 PM
Ok, HAAS doesn't fit
Will try cleaning before gettting my now annual replacement  :(
#5 siztenboots
Posted 13 June 2018 - 06:38 AM
should be lasting years
#6 DX220
DX220
  • 326 posts
Posted 14 June 2018 - 08:27 PM
I'm sure you're right!
Except it seems like, every year for the past 2 - 3 years, car keeps going into limp mode, or turbo goes on strike, etc. etc.
Unplug MAF, problem goes
New MAF
New year - repeat  :ffs:
#7 DX220
DX220
  • 326 posts
Posted 14 June 2018 - 10:38 PM
On a turbo, I don't have an EGR valve do I?
Edited by DX220, 14 June 2018 - 10:40 PM.
#8 siztenboots
Posted 15 June 2018 - 06:55 AM
no egr
#9 DX220
DX220
  • 326 posts
Posted 17 June 2018 - 10:01 PM
Update
Sprayed MAF liberally with this: Wynns Petrol EGR Cleaner
MAF in air intake hose, but unplugged from electrics (and air filter side)
Engine kept idling at ~ 1500rpm
Short bursts of spray to prevent stalling; basically following instructions on can
Well it's only been 48hrs
But...
Finger crossed..
We have liftoff  :jump:
I'd venture to say: better than back to normal!
Chicken count yet to start  :popcorn:
Edited by DX220, 17 June 2018 - 10:03 PM.
#10 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 18 June 2018 - 01:56 PM
New MAF
Welcome to my world.... Every year another one :happy:
You probably have a cone filter / performance type filter?
#11 DX220
DX220
  • 326 posts
Posted 18 June 2018 - 07:54 PM
New MAF
Errr, no!
I do have an Astra H VXR K04 Turbo fitted however.
Maybe that has the same effect?  :mellow:
#12 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 19 June 2018 - 03:51 PM
New MAF
Errr, no!
Nope, nothing to do with the turbo...
#13 DX220
DX220
  • 326 posts
Posted 23 June 2018 - 07:39 PM
well that lasted!
Not  :(
Ruined a nice cross-country drive home with roof off to boot
#14 Nev
Posted 23 June 2018 - 08:16 PM
Perhaps you have a wiring fault leading to the MAF? Try bending the loom feed around with the old "bad" MAF in and see if fixes the problem, also trying inspecting/cleaning the plug as that might be causing a fault.
Edited by Nev, 23 June 2018 - 08:17 PM.
#15 DX220
DX220
  • 326 posts
Posted 23 June 2018 - 08:42 PM
I get an engine warning light when MAF is unplugged, but none when just misbevaing.
I won't get one with wiring fault?
Will try the wrap around  thumbsup
Cleaning the plug was where I started
#16 DX220
DX220
  • 326 posts
Posted 30 July 2018 - 10:18 PM
Belated update.
Having tried lots of things, I was at the point of giving up, and getting new pedal sensor (as suggested by garage).
Cleaned the infamous contacts behind rear wheel arch........
.. got the car back for the summer !  :groupjump:
#17 iram
iram
  • 247 posts
Posted 31 July 2018 - 08:51 AM
the only true way is to ditch the maf and change the ecu for true inner peace!  :beat:
#18 DX220
DX220
  • 326 posts
Posted 11 August 2018 - 01:56 PM
Haven't come across that one before!  :huh:
#19 iram
iram
  • 247 posts
Posted 03 October 2018 - 04:50 PM
worked for me! best thing i did! no more limp mode and tinkering to try and clean them in the vain hope they will work!  relent buy a new one then rinse repeat!
