17" Front Tyre Question About Team Dynamics
Posted 22 July 2018 - 07:50 PM
My question is this; with original 175/55 giving 623.3mm diameter, would I be better off having a 205/45 (616.3) returning to nearer original tyre height. Will the 205/45r17 rub? Anyone else running this setup?
Thanks.
Posted 22 July 2018 - 08:07 PM
If you want to keep your ABS working it's best to keep the delta between the f/r circumferences the same as OEM. If you are struggling with front tyre sizes to do this, then you can consider changing the rears next time they wear out.
I find having a big % profile on the front important too, the lowest % profile I've had is 35% and it is not good for the road, I've also tried 40% and 45% and 50%. 50% is best IMO.
Edited by Nev, 22 July 2018 - 08:08 PM.
Posted 23 July 2018 - 02:39 PM
Posted 23 July 2018 - 03:33 PM
Depends.
I have 7.5x17" wheels on front of mine (DTCs) and with 205/45 AD08R tyres no clearance issues, with 205/45 R888R tyres they rub very slightly on the inner arch liner on full lock. Also depends on ride height etc. Assume the DTC front wheels have same offset as TD but again depends on that also.
Posted 23 July 2018 - 04:25 PM
Posted 23 July 2018 - 04:59 PM
I also have the ATS dtc wheels with AD08R 205/45 17 tyres, no rubbing issues at all
Posted 24 July 2018 - 07:22 AM
Posted 24 July 2018 - 08:38 AM
What offset are your 7.5s? I'll check mine and see how different they are. Only running 7s on the front and gap seems close on rear edge of tyre.
Front DTC are ET20. Another confirmation from my side, no rubbing at all with 205/45/17 Hankook on DTC.
Posted 24 July 2018 - 10:39 AM
Posted 25 July 2018 - 07:17 PM
Posted 12 August 2018 - 02:30 PM
Personally I thought 205/45 was OK for AD08 16 inch. 205/40 AD08 16 inch were tramlining monsters - in fact there was more fight from the steering than any fwd car I have driven. Now have NS-2R in 195/50 16 inch which are far superior for how I drive. Admittedly my car is pretty low.
I have wondered about 17 inch fronts but can't see that there is a gripy 195/40 tyre.
Paul
