#21
Posted 16 August 2018 - 05:11 PM
I know, I'm an arse. I'll get me coat. Lol
#22
Posted 17 August 2018 - 05:36 AM
Sorry, it is possibly the wrong area but as were going from a 120 to a 100 amp alternator, must be classed as a modification now isn't it lol
Martin S
#23
Posted 17 August 2018 - 06:42 AM
#24
Posted 17 August 2018 - 07:07 AM
#25
Posted 17 August 2018 - 11:45 AM
Martin S
This is step 1 in the sc conversion, so it is in the correct place.
Yay! This appeases my OCD.
#26
Posted 17 August 2018 - 12:53 PM
Glad the world balance is back in order.
Now I have just have to get under that bloody car for a few hours of scraping, bruising and swearing.
Martin S
#27
Posted 17 August 2018 - 01:22 PM
#28
Posted 17 August 2018 - 07:21 PM
Done, one new alternator fitted. Got it out via the side, and undone from underneath.
The tensioner was also crudded up and not very flexi but luckily had one here so fitted that as well.
Car has now driven off and all good.
Thanks for all your wisdom, helpful posts from the past and some special socket heads from Jez at back on track.
Martin S
#29
Posted 17 August 2018 - 07:23 PM
now you jsut need to buy lauren a sc kit
#30
Posted 18 August 2018 - 06:58 AM
For future reference to NA owners.
To change the alternator -
Jack up
Remove drivers side rear wheel and wheel arch liner
Remove the mid under tray
Disconnect the battery
Remove the belt (push up the tensioner using the head of a small ratchet)
Using a 14mm E drive socket and ideally a flexi socket (90 degree bend one), undo the 4 bolts of the alternator (now you need two people ideally).
One person lowers it while the other undoes the plug in connection and undoes the 13mm nut holding the main electrical connection.
Undo one bolt holding the black plastic box thing under the wheel arch (excuse my ignorance but seems to be something to do with fuel tank breathing) and
push it out of the way a bit.
Push the alternator from underneath and the other person pull it through then wheel arch side. It slides through easily (ours was the bigger 120 amp alternator).
Reverse the process.
Martin S
#31
Posted 18 August 2018 - 02:43 PM
then find the fault was with the chassis earth strap on the other side
#32
Posted 19 August 2018 - 10:08 AM
It was the alternator I'm pleased to say.
#33
Posted 19 August 2018 - 10:09 AM
trackday go okay then?
#34
Posted 20 August 2018 - 08:23 AM
Were going Friday out to Folembray.
Martin
#35
Posted 20 August 2018 - 04:43 PM
All is good so far thanks to Dad & Aaron thanks for all your in put.
P.S Still not bothered about a supercharger as I love the chase!
Also tagged with one or more of these keywords: suggestions welcome
General Discussion →
Tuning & Modifications →
Best Clutch For A 300 Bhp Sc CarStarted by MartinS , 10 Jun 2015 suggestions welcome |
