It does get quite bitchy on here at times, maybe this isnt a bad name swap after all!!!
History Of The Vx220 Range
#21
Posted 25 September 2018 - 10:41 AM
#22
Posted 25 September 2018 - 11:59 AM
I give in, whats the loo of doom
#23
Posted 25 September 2018 - 12:09 PM
Behind your header tank are a blue and black connector with pins that can corrode over time.
When that happens, you get al sorts of error codes, and funny behaviour.
It's usually fixed with a good clean of the connectors.
#24
'Loom of Doom' - The engine harness to body wiring connectors that reside on the other side of the coolant tank. You can get issues (such as a dead throttle pedal) due to corrosion on the connector plug pins.
#25
Posted 25 September 2018 - 12:49 PM
Yep, loom of doom! An apt typo on my part!
