I have a spare hole in my gauge pod so was thinking of installing oil temp.
Where can I get the sandwich plate to run the temp sender from for a VXT?
Is there anything more I need to know?
Thanks
Posted 23 October 2018 - 07:50 PM
Thanks
Posted 24 October 2018 - 06:42 AM
Its fairly easy to fit the temp probe if you use a threaded banjo bolt above the filter. I bought one with the hole in the top already tapped, but you can remove and drill/tap the original banjo bolt.
