Hi ¡¡
It's my first topic here ¡¡
I'm doing a Saab 2.2 conversion and the mechanic decided to use the Saab thermostat housing (cutting and wellding the gear cable mounting).
Has any of you used this solution?
I think the cooling route could work (closing one of the inlets) but I think I will have problems with the temp sensor wich is diffrerent from Z22SE.
Is it a waste of time to use this housing ?
kind Regards
Edited by Litos, 22 November 2018 - 12:48 PM.
