Removing Steering Wheel (Airbag Light Question)
Posted 06 February 2019 - 11:03 PM
Thanks
Posted 06 February 2019 - 11:34 PM
Posted 07 February 2019 - 12:10 AM
If you trip the light then you need the Lotus kit to reset, OBD won't do it.
Posted 07 February 2019 - 10:53 AM
Ok, thanks Pete
What happens if I want to remove the airbag completely? Is there a part you can fit to switch off the light and maintain it off?
Posted 07 February 2019 - 11:20 AM
220ohm resistor into the old connector with a bit of heat shrink over it to stop it falling out should do you. I have a new steering wheel to fit at some point and have been looking into this recently.
Posted 07 February 2019 - 12:12 PM
https://www.demon-tw...er-kit-sra1212/
Just do all the work with the battery disconnected.
Edited by pete-r, 07 February 2019 - 12:16 PM.
Posted 07 February 2019 - 05:36 PM
Just needs a resistor. I bought one of these because I'm lazy and it worked a treat.
Battery disconnected easiest answer, Opcom can reset light ( in my case anyhow) if you do trigger it.
Posted 08 February 2019 - 10:22 AM
Thanks chaps
