Immobiliser Not Working
7 replies to this topic
#1 oblomov
oblomov
    oblomov
  • 3,885 posts
  • Interests:Mumblers
Posted 04 May 2019 - 06:29 PM
I've done some minor electrical work on the VX (DRLs and hard wire front/rear camera).  This included disconnecting the battery.  I discovered yesterday that the immobiliser is not working.  I haven't actually tried to use it since last summer so I don't really know for sure when it stopped working.  Battery change to the fob has made no difference.
Suggestions welcome.
Thanbks  ob
#2 Richard Hoogeveen
Richard Hoogeveen
  • 73 posts
Posted 04 May 2019 - 06:36 PM
Did you try another key ? And if so move the other out of the way.
#3 Exmantaa
Posted 04 May 2019 - 11:07 PM
Immobiliser is a chip in key and the fob is for the alarm (an not connected to the car ecu)... What stopped working?
#4 oblomov
oblomov
    oblomov
  • 3,885 posts
Posted 05 May 2019 - 12:09 AM
Ah, in that case when I press the fob the alarm does not set (tried another key).
Edited by oblomov, 05 May 2019 - 12:10 AM.
#5 oblomov
oblomov
    oblomov
  • 3,885 posts
Posted 08 May 2019 - 07:43 PM
So still no joy with my alarm.  Fuse 13 is OK.  The alarm sounded twice for the full 4.5 minutes when I was messing about with the electrics and wouldn't disarm with the fob, but still unable to find the problem.
Edited by oblomov, 08 May 2019 - 07:49 PM.
#6 oblomov
oblomov
    oblomov
  • 3,885 posts
Posted 09 May 2019 - 08:50 AM
So things just got worse.  Indicators were working so I tried the hazard switch which didn't work and then no indicators at all.  No blinking red light on the dash either.  Where is the relay for the indicators?
Thanks
ob.
Edited by oblomov, 09 May 2019 - 08:58 AM.
#7 Exmantaa
Posted 09 May 2019 - 09:27 AM
Hmmm, I think the hazard light switch is somehow wired to/through the alarm unit, so these faults may be related...
Relay is at the backside of the lower alloy dash beam (where your knees are)
#8 oblomov
oblomov
    oblomov
  • 3,885 posts
Posted 09 May 2019 - 12:06 PM
Thanks for your help :) .  Checked everything out - no problems found but when I pulled checked and replaced the fuse (again), after  a couple of chirps suddenly everything was working properly.  Still no idea what the problem was.  :unsure:
