Edited by Ivor, 07 May 2019 - 06:11 PM.
Racetcs And Abs
Posted 07 May 2019 - 06:11 PM
Posted 07 May 2019 - 11:13 PM
isnt the sound of misfire the tcs stepping in?
Posted 08 May 2019 - 05:20 AM
Edited by Ivor, 08 May 2019 - 05:21 AM.
Posted 08 May 2019 - 05:42 AM
Yeh I use TCS on track days, I have it wound quite high on dry days, about 30% slip and have 2 wires cut on the abs.
It does kick in still, but very minor as expected.
I take it you have disconnected the abs on the correct side of the signal wires to the TCS?
Sent from my LG-H815 using Tapatalk
Posted 08 May 2019 - 07:01 AM
Hi Ivor,
As above, you disconnect the ABS from the wheel sensor but leave the Race TCS system still connected to the sensors (I assume that you have done this anyway). I do find setting number 1 is too sensitive though (it will cut in just from the deformation of the tyres from hard acceleration sometimes). I have found setting number 3 is ideal for the dry for me. I did also tweak the settings on the program a little, (assuming Jacek used the same base map for all of us) you can wind back the fuel cut settings a fair bit which smooths out the effects of the system, and improves the response a bit.
Posted 08 May 2019 - 10:46 AM
I think so, cut the yellow wire at the abs unitHi,
Posted 08 May 2019 - 10:47 AM
Thanks for This, had it set on setting one I think will try again and adjustHi Ivor,
