Oil Pressure Switch
Posted 17 May 2019 - 07:19 PM
There is a single feed, so I’m assuming this is a 12v feed from the dash light to the pressure switch, which is nc until upto pressure when it then opens....
Posted 17 May 2019 - 07:28 PM
Posted 18 May 2019 - 07:11 AM
the oil pressure switch is just a ground wire, so no oil pressure creates a negative feed to the dash light, oil pressure cuts the negative feed and thus the light goes out.
Posted 18 May 2019 - 07:45 AM
Thanks - so if I bypass the switch and ground the wire directly the light should come on - so resting g if it’s wire or switch...
Posted 18 May 2019 - 08:06 AM
correct
ps: I have a spare new oil pressure sender if yours is duff
pps: brown/blue is the wire colour - https://www.speedste...m/Instument.pdf
Posted 18 May 2019 - 04:18 PM
