To Buy A Snotter Or Not
8 replies to this topic
#1 Howrare
Howrare
  • 1 posts
Posted 28 May 2019 - 08:34 PM
Hello all
Got to go for a short drive in a VX today with a view to buying it. I'm pretty certain it's not the one, to go for as it's got pretty much everything on the hit list wrong with it.
Cat C/D
Tatty inside, ripped drivers seat.
Odd DIY immobiliser switch with loose wires
Frunk release broken.
Low coolant
Cracked sills.
Cracked drivers door top and window rubber buggered.
Paint mismatched on rear clam, and hazing down left side.
I'd say both front links are gone and rack is probably shot
Gear cables are stiff
All 4 wheels curbed
Doors rattle
Drivers seat rocks
So the question is. If it could be bought for very low £££'s, say 3k-4K, worth sticking in another 3-4k to get it completely sorted?
What do you think? Madness, wait for a nicer 7-8k? Probably the sensible option eh? Or bring one sad VX back from the brink
#2 Rosssco
Rosssco
  • 3,955 posts
Posted 29 May 2019 - 01:35 AM
I guess it depends on whether you like a project, and the option to select replacement parts to you own spec (e.g. if its destined to be a track car, you can spend the budget on track spec suspension and brakes, strip unnecessary weight, paint in garish colour etc.)..
Or if you just want a nice road car. A tidied up Cat C/D with say 70-80k miles is only going to get 7-8k tops in the current market. You could get a cleaner, non-cat NA for 8-10k region these days, or a low-mileage one for 10-12k.
Depends what you're after and how much time / money / effort you want to commit.
The key thing is no chassis damage. Anything else is just time / money / effort
#3 paul_mck
paul_mck
  • 32 posts
Posted 29 May 2019 - 06:25 AM
would you get it for 3-4k? surely they would break into way more?
#4 FLD
    Batmans mum says 'I like things in my bum'
  • 13,218 posts
Posted 29 May 2019 - 07:21 AM
You've described most VX's! Other than the DIY immobiliser I'd say it's fairly normal fare for the bulk of cars these days unfortunately. From what I've seen a few unscrupulous VX owners are looking to make money on the car so will skimp on the unseen bits and make good the superficial bits, often with fancy trims etc. Often the ones that look OK on the outside are needing some serious renovation when you get down to the nuts and bolts. Don't forget these are getting quite old now. You need to get right into all the nooks and crannies and have a good look at them. Go see a few before deciding.
#5 ChrisS1
ChrisS1
    Club OEM
  • 8,325 posts
Posted 29 May 2019 - 09:01 AM
Don't know how much it is up for but the list of 'problems' are pretty run of the mill for these cars.
Cat C/D - is it C or D?
Tatty inside, ripped drivers seat - normal for cheap end of market
Odd DIY immobiliser switch with loose wires - remove
Frunk release broken - the handle or the whole mechanism?
Low coolant - top it up
Cracked sills - do you mean sills or the black plastic covers over the sills? If just the black plastic this is normal
Paint mismatched on rear clam, and hazing down left side - cosmetic
I'd say both front links are gone and rack is probably shot - if it has MOT then its personal opinion
Gear cables are stiff - £200 for cables IIRC
All 4 wheels curbed - cosmetic
Doors rattle - normal
Drivers seat rocks - normal
#6 ChrisS1
ChrisS1
    Club OEM
  • 8,325 posts
Posted 29 May 2019 - 09:06 AM
The things you need to check for are items such as condition of wishbones, corrosion between rear subframe and chassis, corrosion between front shock mounts and body, front and rear lights, brake hoses (particularly the one that runs through the sill), records of when the rear toe links were last changed.
Timing chain replacement is nice to have but can also be used as a bargaining tool.
#7 Tibbles Stryker
Tibbles Stryker
  • 1,935 posts
Posted 29 May 2019 - 02:07 PM
Buying a rough one is false economy, buy the very best you can afford, bar a radiator and track rod end mine has been faultless in seven years
#8 vocky
    vx220 itb
  • 11,769 posts
Posted 29 May 2019 - 04:00 PM
sometimes a good cheap vx does turn up, I spoke to an owner recently who had just bought a vx220 for £3k and it was easily worth double what he paid.
That said I've seen some really bad cars over the years, so be careful what you buy.
Mine is one of the very last NA's built and that is now sixteen years old
The most overlooked thing is subframe shims, the damage the corrosion does is scary and it will eventually cause vx220s to be scrapped.
#9 Foxy
Foxy
    I love Nev
  • 10,370 posts
Posted 29 May 2019 - 07:25 PM
Was it the blue one in Wrexham?
