Z20Let / Odb Question Into A Mk2 Astra..
3 replies to this topic
#1 Steve Heley
Steve Heley
  • 3 posts
Posted 06 June 2019 - 06:17 AM
Hello all!.
I'm fitting Z20let into a Mk2 Astra, with the intentions on using a VX220 map as i'm led to believe it has less features than the Astra GSI version.
I've started on the wiring and traced all the wires needed from the ECU connector using the Corsa C fitting guide..
Where it states pin connector 11 / 43 canbus-BCM,i cannot see / find where these wires trace to?    The ECU wire from odb port appears brown/white?
Thanks....
#2 siztenboots
Posted 06 June 2019 - 01:40 PM
VX220 and Corsa are different ECU looms , different pins , so you need both to match
VX220 ECU map does not use CANBUS
#3 Steve Heley
Steve Heley
  • 3 posts
Posted 08 June 2019 - 02:36 PM
Good to know.. What I'm really looking for is how/where the ODB port wiring connects to the ECU?
#4 slindborg
Posted 18 June 2019 - 12:04 PM
https://www.speedste...nostic Link.pdf
and PS its jsut CAN, no fcuking BUS, I dont care what marketing nerds want to call it
