Which Front Wheels And Tyres?
5 replies to this topic
#1 paul_mck
paul_mck
  • 284 posts
Posted 11 June 2019 - 11:47 AM
Hey all, Im sure this has been covered 100 times but what are peoples view on front wheels?
I have the choice of the following fronts (to run with std turbo rears and 225s):
- std fronts with std tyre size
- std fronts with a wider tyre?
- astra 16" fronts and spacers
While drivability is the major goal (on/off track) I do want them to look decent and I think the astras pull it off ok. I also like the idea of staggered diameters like the Lotus cars run.
Not really interested in swapping to TDs etc, I think if I was going that route Id swap hubs and get some lotus wheels.
Cheers all
#2 Spandex
Spandex
  • 107 posts
Posted 11 June 2019 - 04:57 PM
You can get away with running 195's on std front OEM vx wheels. Anything wider needs a wider wheel and different offset to avoid fouling. I have run 3 options: std set-up, 195's on std front wheels and 205's mounted on rear wheels. Horses for courses really..
My opinion as below:
Std set-up is fine for road use.
195's on fronts gives less understeer/more grip
205's on rears up front is better still but arguably unnecessary unless on track
As you progress down the list the tramlining and road noise increases significantly.
#3 scw02102
scw02102
  • 1,581 posts
Posted 12 June 2019 - 01:50 PM
I run rear wheels on the front with 205/45/17 tyres (AD08R)
I ran a 6mm spacers for years which is enough but recently upgraded to 15mm as the wheels still looked to far in the arch for my liking (personal choice)
#4 paul_mck
paul_mck
  • 284 posts
Posted 14 June 2019 - 04:46 PM
any rubbing on the 15mm spacers?
I actually have a pair of 15s but they dont sit over the hub properly. it interferes with the hubcentric part of the spacer
#5 scw02102
scw02102
  • 1,581 posts
Posted 14 June 2019 - 09:30 PM
No rubbing
Remember when you run rears on the front as the offset is -10 difference you need the spacer to push the wheel back out where it should be
#6 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 15 June 2019 - 04:08 PM
No rubbing
I have the same set up rears on the front with spacers only time I got any rubbing was when I lowered the car too much but also got bump steer so lifted it back up again
