After some very hard driving and braking my ABS suddenly came on, speedo and everything working ok and the brakes seem fine, pulling up straight and firm, my excllent local chap just cant hack the electronics so can you help. I tried searching the forum but cant find anything relevant.. does anybody know if there is a g VX ood garage in the northamptonshire leicestershire area. thanks
Abs Light On
Started by
alanwetherall
, Jul 15 2019 03:56 PM
5 replies to this topic
Posted 15 July 2019 - 03:56 PM
Posted 15 July 2019 - 04:57 PM
Had exactly this some time ago, the wire to the L/H/F hub sensor had broken at the point where the wire enters the hub.
Posted 16 July 2019 - 10:13 AM
Find a local owner who has a op-com to check the error code and clear it.
Normally its due to a broken cable at the hub end
Posted 16 July 2019 - 12:18 PM
I’m over between Peterborough and March and can read the code for you if you needed. Unless there is anyone closer?
Posted 17 July 2019 - 03:08 PM
many thanks everybody
Posted 18 July 2019 - 09:19 AM
We are fairly close to you, Just at the top of Bedford - MK44 2QS
