No Charging From Alternator.
Posted 30 July 2019 - 08:54 PM
I tjen got failure P1514.
Stop the car, but tjen IT did not start again. Charged up and started at once
Checking when I was running and IT is no checked the «sense» cable on the alternator but this seems OK.
The alternator is new and I have a eaton m62 supercharger.
Someone know what IT Can be ?
Posted 30 July 2019 - 09:04 PM
People have reported a 1514 in the following situations:
- scangauge set to showing more then 3 values
- faulty injector
- faulty map sensor
- Leak in inlet manifold
- TB clogged up with crap preventing full opening.
What were the latest changes/maintenance you or a garage did to the car?
Edited by smiley, 30 July 2019 - 09:06 PM.
Posted 30 July 2019 - 09:19 PM
Not been there before or after.
Posted 30 July 2019 - 09:41 PM
If you charge your battery and start the car, measure the voltage of the battery with car on and off.
When off, should be around 12v, When running (rev it up a bit) should be near 14 volt.
If you do not get 14v, the alternator is fooked.
Posted 31 July 2019 - 06:29 AM
I did that and it doesn't go over 12,6.
But can it be that a new 100A alternator i dead after a few miles ?
Posted 31 July 2019 - 07:15 AM
Either faulty wiring/connectors somewhere or the new alternator is not working.
Posted 31 July 2019 - 07:58 AM
Is it more than the "sense" wire ?
Where is that connected in the other end ? Should I measure a voltage on this cable when engine is running ?
Does this have a fuse somewhere ?
Posted 31 July 2019 - 04:33 PM
The increased rpm of the charger conversions reduces the alternator life quite quick, i went through 2 alternators before putting an under drive pulley on.
If you need one let me know, they are £100
Posted 31 July 2019 - 05:55 PM
Whats your rev limit ? And have you got an underdrive pulley on the alternator?
6400rpm
Yes i got a pulley on a bracket by the side of the alternator if that's what you mean ?
I meauremd now on the "sense" wire and its no voltage on it. Should it be ? The battery light is not on.
If i need a new one, can you ship to norway ?
Posted 31 July 2019 - 06:00 PM
Posted 31 July 2019 - 06:11 PM
No, its a pulley which replaces the oem pulley on the alternator..
Ok, so the pulley is 100 pounds ?
Posted 31 July 2019 - 06:45 PM
at that rev limit it wont need a oversized pulley
Posted 31 July 2019 - 07:05 PM
yes, but at that rev limit you wont need it.. you only need it if its above 7000 rpm
Posted 31 July 2019 - 07:33 PM
Should it be voltage on the "sense" wire ?
What is the easiest way to change the alternator ? Can I do it through the wheel arch ?
I have a 120A laying around, can I move over the Regulator since this is the most likely to be blown ?
Posted 05 August 2019 - 08:26 AM
Nobody knows ?
Posted 05 August 2019 - 10:35 AM
120 amp alternator does not easily fit a SC, much easier to replace the 100 amp with another 100 amp.
wheelarch is easier, otherwise you need to pull off the SC and lift it out the top.
Posted 05 August 2019 - 06:00 PM
Sent from my SM-G950F using Tapatalk
Posted 05 August 2019 - 07:41 PM
Has your belt fallen off?
No supercharger is still working and ITS around the pulley of the alternator.
