Exhaust Not Sitting In The Middle
3 replies to this topic
#1 scw02102
scw02102
  • 1,581 posts
Posted 10 September 2019 - 07:34 PM
My Larini started off central but seems to have moved off centre now.
This has got worse over time rather than been hit or damaged.
Any ideas before I remove the diffuser etc...
#2 Nev
Posted 11 September 2019 - 06:47 AM
Once the floorpan is off you can use washers/spacers on the mounts to adjust it's position. Easy to do. It's worth double checking that previous owners have used all 4 hanger brackets, it's common for people to not use them all, which makes the exhaust is then more prone to moving.
Edited by Nev, 11 September 2019 - 06:49 AM.
#3 FLD
Posted 11 September 2019 - 07:56 AM
My Tullshit used to go off-centre.  The hangers didn't have stops on so the hangers would slide through the mounts in hard corners (even with my granny driving).  I made some stops up but have heard of people using small jubilee clips to hold it centrally.
#4 scw02102
scw02102
  • 1,581 posts
Posted 11 September 2019 - 07:13 PM
Thanks for the info guys
Was fitted by BOT so most likely been fitted properly.
i will get under there and take a look.
