Need A New Rad - Thoughts? Also What Else Is Worth Doing?
9 replies to this topic
#1 paul_mck
paul_mck
  • 284 posts
Posted 12 September 2019 - 08:41 AM
Hey all, noticed some steam coming from the bonnet at lights, not losing much coolant so think its just spotting out a bit but enough that I want to replace the rad before it explodes on track.
Is it worth replacing the fans as well at the same time? I see rad and fan combos for ok money on the bay:
£175 gets me this which I presume would require a little wiring to interface with the std loom:
What else is worth doing when the clam is off and the innards exposed? Cheers all
#2 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 12 September 2019 - 09:59 AM
Front tow bracket
#3 pete-r
pete-r
  • 2,771 posts
Posted 12 September 2019 - 10:11 AM
I'd get a front clam fastener kit from eBay, half the bolts will be rusted and the other half rounded.
#4 paul_mck
paul_mck
  • 284 posts
Posted 12 September 2019 - 10:17 AM
yeah I have the whole car clam and tray kit ready to go :)
#5 ayresyy
ayresyy
  • 490 posts
Posted 13 September 2019 - 07:26 AM
 You could also look at the front ARB bushes, if they are original they'll most likely want renewing. Also maybe consider fitting a new horn while the clam is off? its massive pain to get to when they stop working.
#6 sford
sford
  • 1,459 posts
Posted 13 September 2019 - 08:12 AM
Chargecooler rad ready for when you SC if you haven't already.
#7 oblomov
oblomov
    oblomov
  • 3,885 posts
  • Interests:Mumblers
Posted 13 September 2019 - 01:34 PM
The first thing I would do would be to establish exactly where the leak is. No point in changing the rad if it's a hose or bleed screw problem?
#8 DanGT
DanGT
  • 146 posts
  • Interests:Cycling, Silly plastic cars
Posted 14 September 2019 - 07:45 AM
As above. Check where is it leaking, could be a bleed screw and you can repair that in situ. If removing the whole rad, I would rather the hoses too. Add a fair bit to the cost but peace of mind etc.
#9 paul_mck
paul_mck
  • 284 posts
Posted 14 September 2019 - 07:59 AM
Seems be around the front lid hinge area so don’t think it’s a pipe. It evaporates before I can get a proper look tho
#10 Arno
Arno
  • 1,238 posts
Posted 14 September 2019 - 09:56 AM
Front tow bracket
This.. Get a stainless one.
The original one is by now likely a collection of rust held together by a thin layer of paint...  :D
