Getting More Neg Camber On Front Wheel
11 replies to this topic
#1 paul_mck
paul_mck
  • 284 posts
Posted 21 October 2019 - 08:30 AM
Hi all, lowered my car on nitrons recently and after getting the camber measurements after alignment it was +0.3deg on the OSF wheel. I removed all the shims (bar the ABS bracket) and got it down to -0.1 ish but not sure how I can get it down to -1 ish for trackdays
any tips? ta.
#2 sford
sford
  • 1,459 posts
Posted 21 October 2019 - 08:45 AM
You can either machine a bit off the hubs/steering arms or run the spitfire steering arms (other aftermarket steering arms are available). They should allow you to get the camber you desire.
http://www.spitfiree...rm-system-vrsas
https://www.elisepar...-steering-arms/
#3 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 21 October 2019 - 08:46 AM
Check your upper arms, you could have a mis matched one on.
Check the design of them side to side.
#4 paul_mck
paul_mck
  • 284 posts
Posted 21 October 2019 - 09:13 AM
good shout!
#5 chris_uk
Posted 21 October 2019 - 09:16 AM
I can sell you the spitfire arms if you decide to go that way.
I had my original ones machines down, which i have somewhere you can have.
#6 paul_mck
paul_mck
  • 284 posts
Posted 21 October 2019 - 09:25 AM
I dont want to go crazy so the machined OE ones might be the best shout, assuming the arms are correct
if you wanted to sell your set Id be interested, else how much am I looking to take off? a couple of mm?
on a sidenote WTF neg camber increase do you get per 1mm shim? Ive seen 0.25 and 0.5deg mentioned and my measurements dont equate to either.
#7 chris_uk
Posted 21 October 2019 - 11:19 AM
as a rule of thumb 0.25 per 1mm shim.
#8 SteveA
SteveA
  • 9,159 posts
Posted 21 October 2019 - 01:52 PM
Be aware that changing the camber will affect toe. Deffo worth checking when you are done to make sure it's inline with what you expect  thumbsup
Also make sure you account for your weight as this can also have an effect (quite a sizable one in a Caterham not sure about a VX though)
Edited by SteveA, 21 October 2019 - 01:56 PM.
#9 paul_mck
paul_mck
  • 284 posts
Posted 21 October 2019 - 04:02 PM
balls, Id been working off 0.5deg per 1mm shim :( Was a thread on here too.
#10 Exmantaa
Posted 21 October 2019 - 05:51 PM
On the Lotus/VX chassis, the toe is not affected by the camber shims. Or maybe a very tiny amount...
A change in ride height affects it much more!
#11 Arno
Arno
  • 1,238 posts
Posted 22 October 2019 - 07:25 AM
any tips? ta.
Camber measured with ballast/driver in car?
Also put a steel ruler across the wishbone tubes. If your lower one(s) is/are bent then you lose camber too.
Normally pulling all the shims, including the ABS bracket should get you close to -1 degree when ballasted (75 kg in each seat, 1/2 tank of fuel).
If you want more then you'll need to machine either the upright or the mounting plinth.
#12 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 22 October 2019 - 05:22 PM
At front.
