Crankshaft Modification
1 reply to this topic
#1 Vladimir
Vladimir
  • 111 posts
Posted 09 November 2019 - 12:33 PM
Is it necessary to modify LSJ crank while fitting ATI harmonic balancer?
I've being reading this thread https://www.cobaltss...71/#post7275934
Edited by Vladimir, 09 November 2019 - 12:33 PM.
#2 2-20
2-20
  • 1,317 posts
Posted 16 November 2019 - 10:13 PM
He has lengthen the key groove to put a longer key.
He says the pulley is only engaged on the key by .25 inch . 2 inches agter modification.
This modification is not needed.
However, check which ATI balancer you install ( oem or underdrive) i think one of them need the machining of the oil pump cover.
