I cant remember where I took it from. I'm not at home at the minute but I can have a look tomorrow.
Aquamist Install Guide
#21
Posted 15 December 2019 - 02:17 PM
#22
Posted 16 December 2019 - 02:49 PM
I took it from the big red (permanent +12V) wire from the alternator.
But you have to install a relais, which is switched by ignition!
You can take that also for additional stuff. There will be enough power on that cable for sure!
In general you can take the +12V from wherever you want if its not a thin cable.
Just make sure the fuse from where the cable comes is big enough.
Edited by FabianG, 16 December 2019 - 02:53 PM.
#23
Posted 16 December 2019 - 09:49 PM
Thanks for the patience with me guys I really have no idea when it comes to wiring and don't want to get it wrong!!
For 12V permanent wire could I crimp one of these on and simply screw it on to the red alternator wire?
For the 12v switch I'm pretty sure I will take this from the green wire on the radio loom as that seems recommended and should be easy for me to do
Then its just the EGR wire and second lambda..... luckily aquamist is going to make me a positive PWM system for me so I won't need to solder anything on the circuit board
Edited by Firthy, 16 December 2019 - 09:54 PM.
#25
Posted 18 January 2020 - 04:01 PM
#26
Posted 19 January 2020 - 12:46 PM
I’ve never had an issue with frozen water in the pipes although tbd I’ve not tracked it in the winter months and don’t use WI on the road.
#27
Posted 27 January 2020 - 10:15 PM
Hi Gents,
Could anyone check that my aquamist wiring is correct??
Firthy
https://photos.app.g...MELyvRsH3wZD1k7
https://photos.app.g...5HcEfb8G7dWKmM6
https://photos.app.g...RXs7cdjxgFBu2X8
Edited by Firthy, 27 January 2020 - 10:25 PM.
