Source For Standard Fuel Pump/sender Units? (2.2 Na)
30 replies to this topic
#21 Spitfire Engineering
  • 755 posts
Posted 15 December 2019 - 10:45 AM
It's a fairly simple install really, not much harder than the 6 hours I wasted fitting a new OEM type pump in the canister in my tank. Hot fuel and vapour lock don't affect me at all, even if I'm just chugging round for 3 hours at 2000 RPM in the summer.
So why didn't the first solution work?
044 noise?
And you installed feeling components inside the pax compartment?
It's worse with a mixture of high output and low output btw as this raises the engine bay temps.
#22 Nev
Posted 15 December 2019 - 12:57 PM
Gary, I notice you are overly picky with everything (but your own stuff).
My solution works fine, never leaks, is durable, can accommodate power hikes and is safe. Hence why I suggested it. Yes it makes noise, if that a worry for the OP then he's welcome to exclude it as an option, however in an already incredibly noisy open top car it's not a real world problem.
There are countless thousands of cars with 044 pumps in them as after-market solutions, with good reason.
Edited by Nev, 15 December 2019 - 01:01 PM.
#23 Spitfire Engineering
  • 755 posts
Posted 15 December 2019 - 06:02 PM
Sometimes, yes but that is for a reason Nev, most people who read these forums are not as informed as some and come here to get reliable information, so it is only fair to give all the advantages and disadvantages of the different options so these can be considered, no?
It has only just been explained on your last post that these are noisy, you may consider the installation safe but I would disagree, having a HP fuel supply fitted into the passenger cabin which may easily be ruptured during a major shunt would not be my choice and I suspect the insurance would take a really dim view of it as well. If you are happy with it that's fine as you take all the risk of course, but endorsing it on a forum without a full explanation would not be fair.
The reason I am not so picky with what we supply is that we have spent a lot of time and effort getting things as good as they can be, the risk is never higher that the OE setup is and usually lower as with the toe links for example.
The comments about the 044 was for an OE VX not the other countless thousands of applications.
Ta
What was wrong with your first installation?
Why did you have to replace it with the 044?
#24 aquilaproejct
aquilaproejct
  • 267 posts
Posted 16 December 2019 - 07:32 AM
Vote #1 no fuel lines in cabin!
#25 Nev
Posted 18 December 2019 - 08:34 AM
You better sell you car then, as the OEM one has fuel lines in the cabin.
#26 Nev
Posted 18 December 2019 - 08:41 AM
Sometimes, yes but that is for a reason Nev, most people who read these forums are not as informed as some and come here to get reliable information, so it is only fair to give all the advantages and disadvantages of the different options so these can be considered, no? Of course, my suggestion was one of several options, I wasn't saying an OEM type pump is bad, simply that an 044 pump is another solution.
It has only just been explained on your last post that these are noisy, you may consider the installation safe but I would disagree, having a HP fuel supply fitted into the passenger cabin which may easily be ruptured during a major shunt would not be my choice and I suspect the insurance would take a really dim view of it as well. If you are happy with it that's fine as you take all the risk of course, but endorsing it on a forum without a full explanation would not be fair. The cabin/seats/fuel tank zone is structurally the safest place from penetration, its in the centre of the car, deliberately protected from penetration by design. Placing a fuel pump on/near the bulkhead area (near the existing fuel filter) is probably as safe a pace as you could find on the car - its where mine is. If the parts are tied down no sort of "major shunt" should dislodge them. The risk is always from penetration IMO, and as I've mentioned, its the safest location/zone in the car.
The reason I am not so picky with what we supply is that we have spent a lot of time and effort getting things as good as they can be, the risk is never higher that the OE setup is and usually lower as with the toe links for example. Im sure you do, and thats commendable. However there are other options in life, one of which is my suggestion.
The comments about the 044 was for an OE VX not the other countless thousands of applications. Precisely, just buying off the shelf VX stuff is NOT the only option. Which is why I mentioned it.
Ta
What was wrong with your first installation? It wasn't powerful enough to deliver for 550 HP. I installed a new pump simply as a lifter pump to supply the swirl pot, the 044 is then next in sequence delivering to the fuel rail. That series of pressure would be enough for 600+ HP, so I have minimal risk of fuel starvation hopefully.
Why did you have to replace it with the 044? Dual pumps, dual fuel filters - a SOP for powerful cars. I chose a sequential setup instead of parallel simply due to size/placement constraints and ease of installation.
Edited by Nev, 18 December 2019 - 08:46 AM.
#27 aquilaproejct
aquilaproejct
  • 267 posts
Posted 18 December 2019 - 10:32 AM
In behind a bulkhead, with a crash shutoff switch, that's been validated to work under a series of physical crash load cases, not to mention simulated crashes.... I'll think I'll take my chances with an OEM style solution thanks.
#28 Spitfire Engineering
  • 755 posts
Posted 18 December 2019 - 12:59 PM
Before I start on the points Nev I would like to point out that at no time on this thread have a promoted my own products or even mentioned them apart from the price difference between the OE units when they were available and more expensive. All the comments were of a factual nature regarding the OE unit spec/availability  and your setup/mods.
But that may change ....   :)
It is an option for YOUR application Nev but not for the OP who doesn't have a 550bhp car so such a pump and swirl pot setup would be wholly inappropriate and would probably cause issues as mentioned before, also he doesn't have a lift pump so for the cheap, low power option he requested info for, this is looking pretty expensive: - 2 pumps, swirl pot, bunch of fittings, extra filter, extra wiring harness, etc.
Because pipes never split? and fuel fitting seals do not pop? the thought of having high pressure atomised fuel spraying an explosive mix inside the cockpit over the occupants is beyond reasonable Nev.
In an impact nothing is protected from the G, I'm sure you have seen slo mo of what goes flying around the inside of the car during a crash, a small heavy item like a pump is unlikely to remain fixed in position and the bulkhead panel* would not take it anyway.
​*Commonly referred to in the aviation industry as a firewall!
​I'm sorry Nev but we will have to differ, I cannot consider such a setup safe, if it were all in the engine bay it would be a different story.
The first question that I ask to anyone asking for a pump conversion is what is the power requirement and future plans, pumps are then selected based on requirement + margin, this keeps fuel recirculation and pump power draw and noise to a minimum, so basically all of the problems I have highlighted before in this thread have been considered before a product is assembled and sold. So effectively the issues mentioned do not exist with out products.
Partly true Nev but it does depend upon a number of factors, if the OP wants OE power and cheap, then options are limited to those requirements, a £600+ VHP installation is not really a solution for him as it fits none of his requirements.
Ta
​OK, well now taking the opportunity to promote our own stuff   :)
The best place for a swirl pot is actually inside the tank (a trapped section) as this cuts down on exposed fuel lines and avoids secondary everything, refill of the trapped section (swirl pot) is very quick and doesn't cost you another pump.
We could have supplied you with an in tank pump unit conversion with the capability of up to 800bhp including margin, this unit would have a working refill for the canister in addition to the trapped section which would allow you to go down to the last few drops of fuel in the tank.
The pump only draws 13.5 amps and supplies 300lph at 70psi so you could have used the OE wiring harness.
You could also use the OE fuel lines and filter.
It would have been much more efficient, much neater, much safer and much quieter, at around £270 + vat I would guess it is considerably cheaper than your installation also??
Even so, I would not recommend this option for the OP though we could fit a much lower output pump to suit his needs, this would be cheaper and very reliable in the long term.
OK, well SOP for modified cars, as the single pump solution is usually hard to achieve and the tank shape usually unsuitable for use at low levels, most cars which have the power as standard use an in tank pump or dual pumps one on each side of the tank to reduce starvation. Obviously the new engines with direct injection have a mechanical VHP pump on the engine.
Thanks for the info Nev
Edited by Spitfire Engineering, 18 December 2019 - 01:08 PM.
#29 Spitfire Engineering
  • 755 posts
Posted 18 December 2019 - 01:06 PM
There are no HP lines in the cabin Nev.
Can you explain?
I don't know any car with this as it is probably not legal on a production car for hopefully obvious reasons.
It's probably outside the rules for race cars as well, at least I hope it is.
The only thing fire related in the cockpit should be the cutoff and the extinguisher!
#30 Mandarin Pete
Mandarin Pete
  • 7 posts
Posted 18 December 2019 - 03:09 PM
Aaaaaaaaanyway, thanks for the info all.
I've managed to free up the level float, which somehow had seized into its hole.
meaning I just need a pump plus filter and ribbed (for my pleasure) feed pipes now.
First though I need to get the tank out, I've got both under-trays off but it seems almost impossible to get to the filler pipes & breather clamps.
#31 FLD
Posted 18 December 2019 - 03:13 PM
The corrugated pipes are about a quid each from Glencoe. I might (and its a very slight might) have an oem pump kicking around.
