Connect Startbutton To Key
2 replies to this topic
#1 Molin
Molin
  • 28 posts
Posted 31 December 2019 - 10:32 PM
Hi
Because of regulation I need a batteryswitch inside the car. My idea is to place it where the startbutton sitt and connect the starter to ignitionkey like a normal car :)  Has anyone done that? Are there a extra wire on the ignitionlock or do I have to change it? Do anyone have a wiringdiagram over the ignitionlock?
#2 Exmantaa
Posted 02 January 2020 - 08:39 AM
The connections are thre in the lock and wiring should be pretty easy. It's a Corsa cullumn/lock, so...
#3 slindborg
Posted 02 January 2020 - 09:06 AM
The starter button is a ground signal for the starter relay
IF you are lucky and your key barrel switch as the start pin fitted (early ones definitely did, later ones might not), they go to 12V on crank.
So you will need a relay to replace the start button. Simple but mild faffing about
